September 22, 2026, 04:34:58 am
| | |-+  Case boring for 94 p&cs - problem
Author Topic: Case boring for 94 p&cs - problem  (Read 8121 times)
qubek
« on: September 10, 2007, 21:11:00 pm »
I just got my case bored for 94 p&c's and there is one thing that bothers me. On other cases I've seen in the past the cut made to place cylinders at the same hight was quite deep. The "step" on which a stock cylinder lies disappears completely. On the one I got, it is not cut down completely. Of course it's much thinner then with stock cylinders.
I made some pictures to show the thinnest place.
I don't know, I'm afraid that it is not enough to support the cylinder. On the other hand, I would prefer not to have the case machined again.
What do you think?
« Reply #1 on: September 11, 2007, 06:14:44 am »
It would work , but it is better to cut the surface down 1,5 mm and use spacers under the cylinder
qubek
« Reply #2 on: September 11, 2007, 18:04:46 pm »
If it should work correctly, then I would leave it as is. The engine will be mild anyway (at least for a while) and I would really like to start the assembly. On the other hand, I don't have time (nor money) to rebuild it again if it brakes Smiley As always - no straight answer.
Thanks for help
« Reply #3 on: September 11, 2007, 18:34:40 pm »
Follow Udo's advice, how else can you set up youre desired compression?
« Reply #4 on: September 11, 2007, 18:35:44 pm »
Aye, do it right the first time and get it decked.
qubek
« Reply #5 on: September 11, 2007, 21:07:31 pm »
Shit. Not the answer I wanted to hear Wink
ugly duckling
« Reply #6 on: October 23, 2007, 06:09:05 am »
deck it. you will have a more stable and wider foundation for wide spacers. hopefuly who ever cuts it there cutters are ultra sharp. if not well they can expect a mag fire when stricking the savers. UD.
