September 23, 2026, 02:51:02 am
| | |-+  JPM Raptor cams
Author Topic: JPM Raptor cams  (Read 7591 times)
69Stu
« on: July 05, 2015, 10:31:41 am »
Hi,
Can any one tell me if the quoted duration numbers for the Raptor cams are measured at 0.050" like other cams, and if the lift numbers are with 1.4 or 1.5:1 ratio rockers. Just trying to determine which one would be suitable for setup.
Thanks.
Stuart.
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: July 05, 2015, 12:06:14 pm »
At 0,05" yes.
The lift in mm is on the cam
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
neil68
« Reply #2 on: July 05, 2015, 19:38:42 pm »
It depends on the source of the quote.  On the CSP website, the advertised duration numbers range from 288 to 332 degrees, so that doesn't appear to be at 0.050" (1.27 mm).
On the JPM website they vary from 251 to 293 degrees (which appears to be at 0.050").  My Raptor cam card only shows the duration at 0.050" (274) and cam lift 10.8 mm.
« Last Edit: July 05, 2015, 19:40:43 pm by neil68 » Logged
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
JS
« Reply #3 on: July 05, 2015, 21:24:56 pm »
Hi,
Thanks.
Stuart.
Hi Stuart, call Johannes and he will suggest or make you one to fit your setup!
Signature.
69Stu
« Reply #4 on: July 06, 2015, 12:49:15 pm »
Thanks for the information.
I have e-mailed Johannes, but haven't had a reply yet. Just trying to work out is one of the standard (CSP listed) cams would be suitable.
