October 13, 2026, 06:13:02 am
| | |-+  Baywindow tire size
Author Topic: Baywindow tire size  (Read 9213 times)
edcraig
« on: July 21, 2015, 18:17:17 pm »
Anyone have a tire size recommendation for a Baywindow bus?  Looking at getting 15" wheels. The Bus will probably not be lowered. I was thinking a 195/65-15 or 205/65-15 with a load range of 94 or higher.
Thanks!  Ed
« Reply #1 on: July 21, 2015, 18:56:54 pm »
Taller than that for a stock height bus. These are about as close to stock as you can get in diameter without getting too wide and having fitment issues:
http://simpletire.com/nexen-sv820-tires
edcraig
« Reply #2 on: July 21, 2015, 19:02:58 pm »
OK. Thanks for the info. I'm ok if they are a little shorter. My tires now are 25.5 tall so was planning on some close to that.
« Reply #3 on: July 21, 2015, 19:53:17 pm »
In that case, Continental makes a nice 195/70r15 (25.7") that would be suitable for a bus. You could get them at a local tire shop.
edcraig
« Reply #4 on: July 21, 2015, 22:36:42 pm »
Ok. Thanks for the info!  Ed
edcraig
« Reply #5 on: July 22, 2015, 22:04:17 pm »
Anyone have any experience with 6 or 7" Fuchs or cookie cutters with adapters on a Baywindow bus. Years ago I has 14x5.5 with no issues but not sure if the 7's will fit with 205 or 216/65's.
Thanks!
benssp
www.callookvw.com
« Reply #6 on: July 23, 2015, 10:12:52 am »
Hi Ed, this site really helps with tyre sizes
http://www.willtheyfit.com/
I've got 5.5x15 ET25 Sprintstars with a 5mm spacer & 195/65/15 tyres on my '69 and they are tight to the arch. If it's a late bus you'll have more room.
www.vwheritage.com  My Job
YMCA
edcraig
« Reply #7 on: July 23, 2015, 18:36:14 pm »
Ok. Thanks for the help!
Fritz
« Reply #8 on: July 27, 2015, 17:21:16 pm »
I run 7" cookies on the rear of my 69 bay, with 195/70 continentals, they are a fight fit, i have 5mm to the arch. This with redrilled drums and exessive camber due to it beeing  lowered, so stock hight with that combo and adapters would probably hit the arch.
DKK TOD
OLDER THAN DIRT!
« Reply #9 on: July 28, 2015, 06:26:25 am »
Hi Ed,is your bay an early(5x205) or later(5x112)?...can make a difference in sizing and needed adapters...I've been down this road with my 71bay(slightly lowered)  Cool
Why is it when it rains kittys....I get hit on the head with a dog!!
« Reply #10 on: July 28, 2015, 17:57:06 pm »
Creative Engineering supplies hubs with 5x130 bolt pattern.
edcraig
« Reply #11 on: July 30, 2015, 21:14:29 pm »
Its a 71 bus so 5/112 pattern.
