September 22, 2026, 06:14:36 am
| | |-+  pop out's fitting help
Author Topic: pop out's fitting help  (Read 7745 times)
beetletom
« on: September 12, 2007, 18:45:41 pm »
car is a 65, do they have the 2 screw holes on the window lip near the b pillar?
and what about drilling the headlining? is there holes behind there? i guess i need a cordless screw driver (a drill!)
and how do i stick on the body to pop out seal (that fits on the seal channel)
« Reply #1 on: September 13, 2007, 09:09:25 am »
Should be 5 holes on the B-pillar, just unpick the headliner slightly so you can see them and pop a hole in the headliner with a sharp point to match the pop-out. in the back there should be the three holes for the latch already there too IIRC. The seal should just clip onto the body - crimp it up if it's not  tight enough.
beetletom
« Reply #2 on: September 14, 2007, 10:26:25 am »
thanks  Cool
beetletom
« Reply #3 on: September 15, 2007, 21:55:51 pm »
now stuck...
there is a bit that clips on to the seal channel
but there is a seperate bar that goes in just behind, but when i fit the screws, they just turn... don't tighten up!
i may not have them totally lighned up...
