September 24, 2026, 12:22:00 pm
| |-+  For sale!
| | |-+  200hp 2110cc NA IDA engine. 2016 season is right around the corner! ***SOLD***
Author Topic: 200hp 2110cc NA IDA engine. 2016 season is right around the corner! ***SOLD***  (Read 4589 times)
Erlend / bug66
Global Moderator
SCC Event
« on: August 18, 2015, 07:29:44 am »
Hi
I'm completing my turbo engine, and I need to sell the NA engine to finance the new set up.
Best time 12.901 at SCC2014 (not optimal gearbox)
Newly tuned and dynoed at JPM. 199,xx HP on the flywheel. The dyno session showed that my "new" digital MSD box was broken, so there is more than 199hp in the engine.
Older analog MSD AL6 box included and working like a champ!
The rotating assembly is balanced to zero.
Specs:
AS41 engine block, no lineboring done. Full flowed.
DPR 76mm crank (VW-journals)
Mahle 94mm cylinders (1 season old)
Wiseco pistons with valve pockets, new rings this winter
Bugpack 8mm head studs (12-point ones)
CB Superrace 5,4" H-beam rods
26mm Shadek oil pump (new right before SCC)
Lightened german flywheel (flattened this winter)
Powerpulley
Stage 2 clutch (flattened this winter)
Scat Silverlight 4-puck
Web 86C cam w/ 1,4 rockers
CB
Chromoly pushrods in Jaycee tubes
CB 044 Wegdeport heads (42mm in, 37,5mm out, heads are slightly modified by JEE Racing
VW650 springs with thin shims (new this winter)
ca. 12-1 i CR (98 octane or E85)
Short IDA intakes by JEE Racing
EMPI IDA's w/ 40mm venturies (some jets and e-tubes included)
AN6 fittings on the carbs
CSP center pull linkage
Large CB 3 3/16 stacks, and the ones that came with the carbs included
1 3/4 Gene Berg exhaust, w/ stainless A1 PhatBoy-muffler and stinger
MSD distributor
MSD Blaster Coil
MSD 8.5mm wires
MSD AL6 box
MSD 3-step box
Old VW fanshroud, no doghause or cooler.
Dynamo with internal regulator
Modified CB breather tower that actually works!
Aeromotive A1000 fuel regulator, return style.
Holley Black fuel pump
Big 10 micron fuel filter
Needed:
Oil cooler, fullflow filter holder and oil lines.
Fuel lines back and forth (AN6 or AN8)
AN6/8 fitting under the fuel tank
Located in Oslo.
Could be delivered at JPM Dyno Day in October
50.000NOK / 5.500 Euros
« Last Edit: August 25, 2015, 16:55:27 pm by Erlend / bug66 » Logged
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: August 18, 2015, 07:33:25 am »
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
« Reply #2 on: August 23, 2015, 10:45:25 am »
Up
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
« Reply #3 on: August 25, 2015, 16:56:12 pm »
SOLD!
The '67:
The '59:
Not yet..
