October 13, 2026, 08:50:37 am
Dot5 Brake Fluid
Topic: Dot5 Brake Fluid (Read 4880 times)
RichardinNZ
Dot5 Brake Fluid
September 05, 2015, 21:07:03 pm »
I've used this in the past but not for a long time. I first used it on the 1302s I rebuilt 20 + years ago. The complete braking system was new including hard lines etc. That worked great. I then used it on my Notch but only replaced front wheel cylinders but flushed the system with meths. It was ok but even after rebuilding the master cylinder I had pressure problems (although that still may have been the master cylinder).
For the '58 I have new rear wheel cylinders lined up with my Type 3 brake conversion along with new Goodrich hoses but wondered whether it was worth renewing the front cylinders and master cylinder too and using DoT5.
What experience have others had and what is your advice?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
RichardinNZ
Re:
September 06, 2015, 03:02:06 am »
I've realised that I probably need to confirm that when I say DoT5 I mean silicone brake fluid rather than DoT5.1 which is a traditional brake fluid
Richard
Dual Carb 36hp
Jesse Wens
Re: Dot5 Brake Fluid
September 07, 2015, 10:31:54 am »
I did it on my fastback when everything was renewed. Very happy with it.
No issues
RichardinNZ
Re:
September 10, 2015, 07:11:27 am »
Thanks for the reply. I wonder whether I ought to best replace everything if I use it.
Dual Carb 36hp
Jesse Wens
September 10, 2015, 11:00:45 am »
I replaced everything so no advice on rincing or cleaning.
RichardinNZ
September 10, 2015, 21:52:32 pm »
Thanks for the reply. I may hold off given the potential need to replace everything.
Richard
Dual Carb 36hp
