September 25, 2026, 20:33:59 pm
| |-+  For sale!
| | |-+  Sold
Author Topic: Sold  (Read 3238 times)
« on: September 08, 2015, 16:19:06 pm »
2332 race engine for sale
Long block is
Mag case, bored for 94mm cylinder, stroke clearance, modded for BMW center main bearing, full flowed etc
Scat pro comp wedgemated crank with matching flywheel, type 1 mains with type 4 center main
Scat 5.5 h beam rods
Wiseco coated pistons with long cylinders
CB 044 wedgeport heads, CB VW650 springs, Ti retainers
Engle FK 89 cam with scat lifters
Scat 2 quart sump
Kennedy clutch with super daikin disc
26mm full flowed Shadeck oil pump & scat billet oil pump cover
Scat H/D 8mm head studs
Fast fab push rod tubes and manton push rods
Fast fab fuel pump block off with vent
Scat straight cut cam gears
Scat billet pulley
Stock doghouse oil cooler
13/1 compression
Has run mid 11s in full weight steel car, should go 10s in lightweight race car with correct gearing etc Wink
Had check and freshen up and just run up on stand, ready to go.
£3900
Also can sell turnkey with Italian 48mm IDAs, match ported manifolds, Tayco linkage header and MSD set up for extra, just ask Smiley
« Last Edit: September 14, 2015, 08:28:38 am by richie » Logged
« Reply #1 on: September 13, 2015, 10:49:48 am »
Pending  Smiley
« Reply #2 on: September 14, 2015, 08:29:05 am »
SOLD  Smiley
