September 23, 2026, 20:17:10 pm
AS41 Mexican Case, 94mm/Full Flow
Topic: AS41 Mexican Case, 94mm/Full Flow (Read 2366 times)
September 20, 2015, 09:33:03 am »
I have for sale a Mexican AS41 Case (new at some point as no engine numbers)
It has been bored for 94mm Mahle cylinders, step cut properly.
Has also been machined for full flow and plugged at oil pump end as well.
This case has been used and been line bored before with a thrust cut. For some reason the centre main has had less of a cut than the other main journals. I have spoke to Stateside tuning who are more than happy to re-line bore the case again to male them all the same size but I have another case that I going to use.
Lifter bores are all nice.
A cheap way of building a motor
Will get pics later
£150
