July 23, 2026, 20:52:13 pm
| | |-+  Need help with measurements on 4" AA cylinders
Author Topic: Need help with measurements on 4" AA cylinders  (Read 4659 times)
Peter S
« on: October 06, 2015, 22:41:21 pm »
What outer diameter are the 4" AA Performance cylinders at the bottom/foot? Anyone out there that have a set and can take that measurement for me?
I'm about to have my wbx-case cut for cylinders and plan on using other cylinders but would like to be able to use the AA as plan B if plan A backfire  Wink
« Last Edit: October 06, 2015, 23:26:59 pm by Peter S » Logged
I'ts closer than ever....
spoolin70
« Reply #1 on: October 07, 2015, 06:48:27 am »
Morning Martin
When are you getting your case cut ?
I can get the measurement for you but won't be till Saturday (hopefully) as my parts
are coming out of hibernation for a little trip  Cheesy
Darren
Peter S
« Reply #2 on: October 07, 2015, 09:05:13 am »
The case will be cut when I tell him to, so there is no absolute deadline.
If you can get the measurements this upcoming weekend that will be fine.
T11964
« Reply #3 on: October 07, 2015, 09:43:20 am »
Bottom of cyls. 106.5mm
Going same route as you , wbx case ( early) .
Peter S
« Reply #4 on: October 07, 2015, 10:06:39 am »
Thanks!
I was about to have my case cut Ø107mm, but that seem a bit too much for a cylinder Ø106,5mm i diameter.
I was recommended a play of 0,2mm. Cutting the case Ø106,7mm should therefore be more appropriate.
