October 12, 2026, 11:59:48 am
| | |-+  pro turbo notch
Pages: 1 ... 3 4 [5] 6 Print
Author Topic: pro turbo notch  (Read 163689 times)
dannyboy
« Reply #120 on: February 22, 2018, 21:32:49 pm »
no worries mate ,stussyrich car is a lummus chassis  mine is a andy robinson chassis  to be completely honest i didnt have any input into my cars design other than giving him the  wheels i wanted to use the rest i left up to the chassis builder i then got axles made to suit the car
8.77@156.8mph
O/FF 60
Ragtop
8.93 at SCC 2012
« Reply #121 on: February 23, 2018, 20:03:06 pm »
In regards of RLR chassis and the rear narrowing it’s up to you when you order. You can get them with both 3” and 5” . Mine is 5”
stussyrich
« Reply #122 on: February 23, 2018, 21:59:11 pm »
here are a few pics for you.
I'd say you won't get an 8.5 wide tyre under the arches with a 3 inch narrow rear.
you can see how tight it is and how close the rim / tyre are to the ladder bars. I have 1 inch from tyre to ladder bar.
hope this helps.
« Last Edit: February 23, 2018, 22:04:16 pm by stussyrich » Logged
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
hotstreetvw
« Reply #123 on: February 24, 2018, 06:33:22 am »
I must admitted this has me a little worried.  Enough to run out in the garage and pull a wheel/tire off my split and check it out.
This is my 2-1/2" backspace wheel. At 4-1/4" off the spring plate.  I measured the split and the face on the hub is about 5-3/4.  So this wheel is where a 4" back spacing would sit.  It's tight, like maybe not get the wheel off with the fenders on tight.  I'm not sure what will happen when the suspension articulates.
« Last Edit: February 24, 2018, 07:03:33 am by hotstreetvw » Logged
dannyboy
« Reply #124 on: December 02, 2018, 23:37:14 pm »
so work has been slow on the turbo setup .a few other cars got in the way .back on it now the motor is built and fitted plumbed in ,the loom is going in  .ive made the new wheelie bars and fitted  hopefully have it running by early jan .....
8.77@156.8mph
O/FF 60
« Reply #125 on: December 06, 2018, 16:57:29 pm »
Wow thats amazing! 2019 will be the PB year then!
is it a TF1 case?
dannyboy
« Reply #126 on: December 16, 2018, 20:32:27 pm »
fingers crossed it will run well .yes its a tf1 case .really nice cases
8.77@156.8mph
O/FF 60
dannyboy
« Reply #127 on: December 16, 2018, 20:33:07 pm »
 Cool
8.77@156.8mph
O/FF 60
« Reply #128 on: December 17, 2018, 23:03:35 pm »
I'm trying to work out if I've actually seen this in the flesh, but I guess you'll be doing plenty of meets at the Pod next season? Did you have it at Shakey for the Cal Look Drag Day last year?
My wife wants to know where the headlights are - she says they're not real cars without them!
dannyboy
« Reply #129 on: December 17, 2018, 23:22:08 pm »
you probably see it at shakey last year as i was testing the car with the  nitrous motor and box out of bug . Smiley
8.77@156.8mph
O/FF 60
WhiteTrash
« Reply #130 on: December 18, 2018, 17:45:01 pm »
Have you been working on the X1/9 I can see in the background? You rebuild it???
Frank
HOFF#67
dannyboy
« Reply #131 on: December 18, 2018, 18:45:30 pm »
Hi mate .no it's a track car project I acquired old fiat has gone to new owner to rebuild for next year
8.77@156.8mph
O/FF 60
WhiteTrash
« Reply #132 on: December 18, 2018, 19:57:35 pm »
Ah nice one. I'll live again then. Still in the UK?
HOFF#67
dannyboy
« Reply #133 on: December 18, 2018, 23:18:22 pm »
yes mate it'll be out next year i think  Cool
8.77@156.8mph
O/FF 60
dannyboy
« Reply #134 on: January 01, 2019, 00:12:33 am »
good few days doing bit and bobs on the car decided i dint like the rubber dash so welded it up and painted it ...
8.77@156.8mph
O/FF 60
« Reply #135 on: January 01, 2019, 11:21:04 am »
Really like the dash Danny.
Has the turbo motor ran yet?
dannyboy
« Reply #136 on: January 01, 2019, 19:58:30 pm »
not yet  still a little wiring to do but hopefully this month it will be on dyno   Shocked
8.77@156.8mph
O/FF 60
« Reply #137 on: January 01, 2019, 20:35:56 pm »
It's going to need some strapping down  Shocked
dannyboy
« Reply #138 on: July 21, 2019, 22:14:50 pm »
so the car is finally ready for testing on track ...fingers crossed it will be ok for a few gentle test passes at bugjam   Shocked
8.77@156.8mph
O/FF 60
Airspeed
« Reply #139 on: July 23, 2019, 11:03:40 am »
What are the engine specs Danny?
I've seem to have missed that part in the thread  Wink
Tnx!
dannyboy
« Reply #140 on: July 23, 2019, 17:13:22 pm »
hi walter its a 2720cc tf1 case scat flange crank pauter rods cant remember the sspecs on cam and turbo but should make enough power to run easy 9s  gearbox is a 091 fully seq box with flat shift (when I can get round to configuring it) Roll Eyes Cheesy
8.77@156.8mph
O/FF 60
Airspeed
« Reply #141 on: July 23, 2019, 18:51:27 pm »
Wow! 2,7ltr should spool most any turbo pretty easily  Cool
Good luck chasing that 8 !
dannyboy
« Reply #142 on: July 28, 2019, 22:29:44 pm »
test passes went good  .first pass I forgot to adjust wheelie bars so it hooked up and pulled a big wheeile so had to back off but did a 1.44 60ft and ran 10.6  so all good then second pass it didn't 60 ft so well but ran 10.3 (works much better with fuel in tank)  all on 0.5 bar of boost so time to turn it up and add a little more boost for green light nats  .car is in lockup ready to go  Cheesy
that was Friday then it pissed with rain all weekend.....
8.77@156.8mph
O/FF 60
« Reply #143 on: July 29, 2019, 21:53:48 pm »
There's a cracking wheelie photo on Eurodragster! Shame about the weather, it was a really good turnout.
dannyboy
« Reply #144 on: July 30, 2019, 19:48:41 pm »
yes really nice pic cheers .was great to see so many cars there
8.77@156.8mph
O/FF 60
dannyboy
« Reply #145 on: August 04, 2019, 21:13:44 pm »
https://youtu.be/psWrrHxCFiU
8.77@156.8mph
O/FF 60
dannyboy
« Reply #146 on: September 06, 2020, 20:28:56 pm »
car is back at track with ecu and fuel system upgrades ran 9.1@152mph on sat then the alternator shit itself stopping play very happy with that and looking forwars to more testing soon Cool
8.77@156.8mph
O/FF 60
PPRMicke
« Reply #147 on: September 07, 2020, 10:15:28 am »
Cheesy Cheesy Cheesy
Congratulations on the new PB
/// Micke
« Reply #148 on: September 07, 2020, 10:35:13 am »
Well done Danny, that MPH is awesome  Grin
« Reply #149 on: September 07, 2020, 16:39:46 pm »
Really impressive - was watching live. Well done!  Cool
