September 09, 2026, 23:45:45 pm
Latest Member: Bad Habit
| | |-+  Custom length tie rods
Author Topic: Custom length tie rods  (Read 8077 times)
« on: October 21, 2015, 14:38:53 pm »
I want to make some chromoly tie rods (the tubes not the tie rod ends)
I am looking to buy 4 threaded inserts (2 righ hand thread, 2 left)
Anyone know who stocks them in the uk?
I believe track rods ends are M10 thread?
This is what I am after
http://www.speedwaymotors.com/Steel-Weld-Bung-for-1-Inch-ID-Tube-5-8-18-LH,39130.html
« Last Edit: October 21, 2015, 15:40:51 pm by leec » Logged
Doogster
« Reply #1 on: October 21, 2015, 14:44:19 pm »
Try a comapny in Aberdeen called Grampian Fasteners. 01224 772777
« Reply #2 on: October 21, 2015, 15:20:34 pm »
Just looked on their website, with no luck
Doogster
« Reply #3 on: October 21, 2015, 15:47:21 pm »
I would give them a call Lee.  Wink
Andy Sykes
« Reply #4 on: October 21, 2015, 16:28:39 pm »
stock ends are m12x1.5 McGill Motorsports sell them in most sizes and super fast delivery
« Reply #5 on: October 21, 2015, 17:07:07 pm »
Andy,
Just phoned them but they currently only stock unf sizes.
Andy Sykes
« Reply #6 on: October 21, 2015, 19:10:49 pm »
Ok eBay search in 20 seconds found loads of them about £3 each
« Reply #7 on: October 21, 2015, 19:15:57 pm »
Like the style I posted above?
spanners
« Reply #8 on: October 25, 2015, 19:06:42 pm »
I don't know anyone inserting tie rods, wishbones yes, but Its best done anyway with the minimum hardware and welding, why add weight and complexity and weak points, just use 1/2" I'd tube and tap to suit , I use rod ends for racing, they don't have the thread reach of the stock tie rod ends, so I use butted lock nuts rather then clamps. One aside to up rated tie rods can be a damaged steering box or rack, I only up grade when I have to, wider axle for example, the stock rods are good, very good, I've only ever bent one, the weaker long one, by hitting a bank at speed with the left front, id rather bend a tie rod than break anything further down the shock path,  especially my thumbs, as this may stop me hitching home, Wink best regards, spanners.
Best regards, spanners.
