September 24, 2026, 01:29:44 am
| | |-+  Wheel hop
Author Topic: Wheel hop  (Read 11056 times)
andy198712
« on: October 28, 2015, 19:06:48 pm »
Hello,
Had my first real experience of proper wheel hop the other day in my beetle.
Pre loaded the gearbox on the clutch and hand brake and fed in the power and the rear spun up (guessing one wheel), and all was fine for a short while till it gripped and i got a nasty hop!
So normal option to combat this seems to be a traction bar, only my beetle has a removable rear end so i'm not so sure how much force i want to be putting on the rear end like that?
What are the other options?
I know of the Kafer bars setup.
but also see Dawn's beetle had "rabbit ears" that Ray (RIP) had made which looked good too...
What are people using in street cars? its got all new stock rubber mounts and is swing axle.
Kind Regards
Andy
« Reply #1 on: October 29, 2015, 00:32:29 am »
Kind Regards
Andy
I used a camber compensator, rubber snubbers and hefty preload with straps (bumps stops touching at rest).
But that's coz I had it all anyway, probably "nicer" ways out there.
« Last Edit: October 29, 2015, 00:36:02 am by modnrod » Logged
Iryanu
« Reply #2 on: October 29, 2015, 11:54:53 am »
Hello,
Kind Regards
Andy
Some good methods at the bottom of the page here. Bracing up to the parcel shelf is the only option if you've not got provision for a berg bar or similar. Or the CSP torque bar.
http://www.funkenblitz.com/fitting.shtml
My car suffers from wheel hop even if I pre-load the box, as soon as the tyres break traction the sledge hammering begins, my box is solid mounted with a mid mount to boot.
I've also heard that a CSP torque bar eliminates wheel hop although I have read that it doesn't work for all people, whether that is due to people not pre-loading the bar when fitting I couldn't say.
I'll probably go with the CSP bar or the Berg bar as I don't want to be cutting my shiney new parcel shelf panel.
Ryan
andy198712
« Reply #3 on: October 29, 2015, 19:35:46 pm »
Cheers guys, i've got a CC i could refit.
I need to have a look and see if i can fit a torque bar, got a cooler and filter in the parcel area.... will check next time i get it on the ramps.
direct to the parcel area looks easy enough to do though and solves the issues pretty solidly! might need a rubber sheet in-between it otherwise i can see that being very noisy otherwise...
 Cool
andy198712
« Reply #4 on: October 29, 2015, 19:36:46 pm »
That said after i pulled out of a junction today the inside wheel spun up in wet leaves and not a hint of hop  Roll Eyes
« Reply #5 on: October 29, 2015, 22:19:38 pm »
Wheel hop only occurs in a straight line.  Add a slight curve and you prevent all hop.
mg
« Reply #6 on: October 30, 2015, 15:47:55 pm »
So after I preload the trans with the handbrake, rev the engine side step the clutch and then turn the wheel?  Wink
Jesse/DVK
'64 2176cc
« Reply #7 on: November 01, 2015, 16:11:27 pm »
I also have a removable apron but used a berg traction bar with succes. Used the holes which are already in the body for the hangers.
andy198712
« Reply #8 on: November 02, 2015, 19:56:34 pm »
i'll look into that as its very easy and cheap to do.... do you preload it a bit from "resting" height? could quite easily make my own too i think from strong rectangle or box section
« Reply #9 on: November 02, 2015, 20:16:30 pm »
I would thoroughly recomend the Funkenblitz mod posted in the link above. That combined with cb performance rhino mounts and a berg mid mount and traction bar gave me no wheel hop even at the drag strip before I had a cage fitted which went down to the frame horns.
For me wheel hop is also reduced by the correct tyre choice/pressure and shock absorbers. koni reds are by far my preferred choice.
If done right, you don't have to drill many holes in the firewall/package tray when doing the funkenblitz mod.
Lee
spoolin70
« Reply #10 on: November 02, 2015, 20:47:51 pm »
+1 for Rhino mounts
I used this with a CSP bar and cage down to the ends of the frame horns.
Car never had a single hop. I did quite a lot of hopping a couple of weeks ago though  Cheesy
andy198712
« Reply #11 on: November 03, 2015, 19:04:20 pm »
i'm no doctor but......  Shocked
Thing is i have the 73 and later front mount and they don't make them for that... which doesn't help that i have softer mounts anyways, although new.
i might make up a conversion bracket for the front maybe, doesn't look hard tbh.
i'll look into the traction bar idea, wondering how much sound that under parcel shelf option will transmit to the cabin?
cheers for the advice its all very helpful!
andy198712
« Reply #12 on: November 03, 2015, 19:04:39 pm »
oh and Koni Reds are defiantly on the list
« Reply #13 on: November 03, 2015, 21:31:06 pm »
Rubber mounted mid mount will help as well Smiley
Darren you need to wash your feet, all that dirt on there  Shocked Cheesy
andy198712
« Reply #14 on: November 05, 2015, 20:56:40 pm »
yeah been looking at those  Grin cheers buddy!
kingsburgphil
« Reply #15 on: December 24, 2015, 01:43:20 am »
Try dropping the tire pressure. My DOTs wheel hop like mad at 25 lbs.
14lbs. no problem  Wink
cedric
« Reply #16 on: December 24, 2015, 05:55:15 am »
My wheelhop is gone..did some tracion bars from RLR on the framehorn..
