September 21, 2026, 00:02:34 am
Latest Member: Bad Habit
| | |-+  Magneto switch question
Author Topic: Magneto switch question  (Read 4991 times)
RobtheManx
« on: November 01, 2015, 12:58:23 pm »
Hi all .
I'm gonna be running a magneto in my street car . Obviously I can just use the old live wire which would normally run to the coil , and run it to a separate switch which earths it .
My question is , I would like to be able to turn the mag off with the standard ignition switch . When I turn the switch on , surely it could turn another switch off to un-earth the mag . Simple stuff I'm sure , but I'm not much of an electrician .
Andy Sykes , you're good with wires n stuff !
Cheers , Rob
Sam K
« Reply #1 on: November 03, 2015, 05:35:33 am »
I wired a relay to ground my mag when the ignition was switched off.
Rocket Ron
It's old school for a reason
« Reply #2 on: November 03, 2015, 08:28:17 am »
Hi Rob
I've used the autometer rev limiter box  before and this makes the mag work on the ignition key, you can alway hide it under the rear seat if you don't want it on show and you get a bit of high rev insurance as well
You could do a search on my for sale adds which will show you the one I was using. That one is sold but they are a good piece of kit
Regards Ron
13.12 @ 101.84
Grooving out on life
RobtheManx
« Reply #3 on: November 03, 2015, 10:04:28 am »
Yeah I was thinking a relay was the way to go , but a rev limiter could be a good idea too ! not that I ever miss a shift of course !
Cheers , Rob
JS
« Reply #4 on: November 05, 2015, 07:22:26 am »
Hi Rob.
I too have the Autometer Pro Control. Itīs 70īs tech, but it works fine. Get a user one cheap on eBay.
Johnny.
Signature.
Taylor
« Reply #5 on: November 05, 2015, 18:35:55 pm »
I woukd think you just need to wire a normally closed relay.  Power on opens relay, power off closes it.
