October 14, 2026, 01:17:35 am
release bearing clearance
Topic: release bearing clearance (Read 8852 times)
Andy Sykes
November 07, 2015, 16:25:32 pm »
Hi
anybody with the engine out of their car could you measure from the front of the cluch release bearing to the back of the bell housing please
Andy Sykes
Re: release bearing clearance
November 12, 2015, 21:12:53 pm »
Anybody ?
November 12, 2015, 21:22:21 pm »
Engine is out cab now so can measure for you, will bus box measurement do? and when you say back of bellhousing do you mean near front of car or where engine mounts to?
November 12, 2015, 22:08:40 pm »
I could measure a type 1 box if you can wait till Sunday? But as Richie asked can you confirm where you want it measured to
Lee
spanners
November 12, 2015, 23:28:00 pm »
It's a variable rather than a given dimension, a 2mm wear factor in use is reasonable on a clutch disc and will cause about 20/25mm adjustment variation on the fingers, self adjusting with hydraulic, or twirl the wing nut with a cable, with no cable attached on a T1 'box, the bearing sits relaxed back on the guide tube flange, I measured on the front most of the sliding witness marks on the guide tube and got 30MM, again, my set up is 3 puck paddle plate on KEP S2 pressure plate late type with no pad, the thicker black magic discs would push the cover plate fingers nearer to the flywheel, increasing the measurement required, so an average figure would be 30 to 40 MM with a T1box, stock clutch.
With my twin disc Sachs clutch, I had to 'stack' the release bearing in order to reach the pressure plate fingers with correct running clearance. The late bus boxes use a deeper bell housing for the big 228mm bus clutch which is also deeper then a T1 clutch, hence the extended bell and long nose starter pinion and extended input shaft they use to reach the flywheel, it was a bus box I had to stack the release bearing in order to reach the clutch fingers, hope that helps, but every set up is different and that's not getting near the Porsche/mendeola variables.
Best regards, spanners.
Andy Sykes
November 13, 2015, 11:36:43 am »
thank everybody I need to work out how much space I have to fit a concentric hydraulic release bearing so I need it from the back of the bell housing near the input shaft to the front of the release bearing if that make more sense
cheers andy
November 13, 2015, 17:49:53 pm »
38.87mm on old cab, but release bearing is adjusted to take up some of free play so that's not minimum measurement it can be. I think you need to fit a stock bearing to your box and measure it really as mendy stuff is not actual vw so fork might be different thickness etc
Andy Sykes
November 13, 2015, 18:13:12 pm »
Ok thanks that gives me an idea I don't have fork as I wasn't sure what I was doing, but I have a plan just need to see if I can find a bearing now
Cheers Andy
Phil West
November 23, 2015, 13:58:27 pm »
Quote from: Andy Sykes on November 07, 2015, 16:25:32 pm
Hi
Measured mine today - 55.5mm. 40mm with clutch depressed. Cheers
Phil
