October 12, 2026, 19:24:51 pm
french 67 savanah
Topic: french 67 savanah (Read 53898 times)
bzh67
french 67 savanah
December 06, 2015, 11:53:22 am »
hi guys , i'm a french guy on the vw scene since 20 years , and always dreamming about building my own cal look with a stroker engine
so my dream come true with the start : buying a 67 model
i found it at 5 km from my house , she was in good shape and still original
plan is no to restore it but just to transform it
engine is going to be a 2276
bzh67
Re: french 67 savanah
December 06, 2015, 12:34:16 pm »
after 1 year runing with it , i park the car in my garage , and starting remove all the mechanic
then clean front
and after repaint
Straight Time
December 06, 2015, 13:02:33 pm »
Nice find. Keep us upto date !!
No retreat, No surrender !
paul_bish
December 07, 2015, 21:31:02 pm »
very nice. Good colour
bzh67
December 09, 2015, 22:43:24 pm »
here is the spec for the engine
TECH SHEET :
- 2276 cc (CB 82 mm x 94 mm)
- VW MAG CASE ; FULL FLOW ; CR 8MM HEAD STUDS
- 30MM OIL PUMP
- CB H-BEAM RODS
- CB2288 Camshaft ; CB LIGHT WEIGHT LIFTERS
- CB STRAIGHT CUT CAM GEAR
- Scat 1.4/1 ratio rockers
- CB 044 HEADS, 44 x 37.5 MINI WEDGE
- 48 IDF WEBERS ; BIG BEEF MANIFOLDS ; CB FUEL PUMP
- 009 ; MSD 6AL IGNITION BOX
- 1 3/4" HEADER LOW DOWN A1 ceramic
- kennedy stage1
want it to look like first looker ,
all the parts are in my garage , and a good friend of me , start building the engine he live at 2 kms from my house , so easy to go and drink beer in his garage !!
think he "s a lounge member , Erwan are you here?
Last Edit: January 22, 2016, 00:04:46 am by bzh67
cedric
December 10, 2015, 08:00:37 am »
Good luck!i did the same..took me 5 years..but i am happy...
bzh67
December 13, 2015, 11:42:46 am »
collecting parts
celtik
December 17, 2015, 18:51:43 pm »
Quote from: bzh67 on December 09, 2015, 22:43:24 pm
Yes a lot!!!
bzh67
January 07, 2016, 22:18:33 pm »
look what i receive today , an original set of empi 5 gt , i'm so happy , but one of them need a little welding ,
i found them here in France , they were from a guy who just have import a vw baywindow t2a from california
i know that center cap are china model , anyone have a red empi gt center cap ? , i need the model to make a reproduction ( i saw a set on the samba but too expensive for me , and i think too small for the reproduction cap ,
alex d
January 19, 2016, 22:02:14 pm »
looking good! what tire sizes are you thinking?
bzh67
January 20, 2016, 23:05:12 pm »
hi thanks ,
i just found 2 michelin xzx in 145/80/15
and for the rear i'm in conctact with a guy who sell 2 avon CR6ZZ in 205/70/15 ( remove from a typeE JAGUAR)
but first i will run with my BRM in 4.5 and 5.5 with 145/80/15 firestone f560 and 205/70/15 federal
i send picture soon
see you
thehanz DVK
January 21, 2016, 21:27:52 pm »
Looking good , Nice car and plans
alex d
January 22, 2016, 11:26:24 am »
Quote from: bzh67 on January 20, 2016, 23:05:12 pm
hi thanks ,
i send picture soon
see you
I assume you will run short axles then?
56BLITZ
January 22, 2016, 19:34:18 pm »
Quote from: bzh67 on January 07, 2016, 22:18:33 pm
IMO . . . The BEST looking VW wheel ever! The repros do not do them any justice!
bzh67
January 23, 2016, 12:27:33 pm »
[/quote]
Yes i just finish to convert the gearbox to short axle , i found short axle at the last european bug in , but was missing the bearing cap witch are spécific , after 3 months looking around me , i found a very good stainless model at ISP west , put pics later
here is some pics about the front beam
it's an oem that i cut and shortened 6cm ( 2") , and weld a sway a way
idea was just to put the Wheel Under fender with the CB dropped spindle + vw disc brake ( 4x100) + adaptator 4x100 / 5x205 and the result is pretty good to me
here is the result with the 10 years old brm 4.5x15 mws ( ET 11 i think )
February 05, 2016, 19:24:04 pm »
Looking really nice
bzh67
February 11, 2016, 00:25:15 am »
i work a little on the car
first i clean the floor and paint it
after i made my homade carpet , in order to get a good result i made some Template
and cut in the carpet
and test /ajust all in place
at this time carpets are at a friend auto interior to sew a vinyl border
February 11, 2016, 21:38:39 pm »
That looks great, nice colour combination.
Steve67
February 11, 2016, 22:21:54 pm »
great car, the carpet looks very good in combination with the savanah beige paint!
jamiep_jamiep
February 12, 2016, 23:30:52 pm »
looking good!
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
celtik
February 14, 2016, 16:23:09 pm »
The engine is "in stage".
Last Edit: February 14, 2016, 20:50:44 pm by celtik
jamiep_jamiep
February 15, 2016, 10:42:14 am »
Now THAT'S progress!!! Awesome
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
February 15, 2016, 23:20:21 pm »
Looks great, more infos about the engine your are bulding?
bzh67
February 16, 2016, 00:40:20 am »
hy , so for the TECH SHEET look at the top of my thread
at this time celtic ( my friend) need to work on the cylinder heads
in the other hand , i'm working on the car , the 67 is near to go on the flloor after about 1 year
i finish the rear axle ( convert to short axle with a street drag gearbox 8x33 , 0.82 ) and finish front and rear braking last week end
get some dificulties with brake liquid around the line lock , but now it"s ok
[/UR
[URL=http://www.hostingpics.net/viewer.php?id=867597IMG0569.jpg]
rear brake are stock for the moment , but thinking about something bigger in few month
BRM 's are ready
and last one for fun
February 16, 2016, 05:09:22 am »
Quote from: bzh67 on February 16, 2016, 00:40:20 am
Great work! Which model/brand set did you use for this?
bzh67
February 16, 2016, 23:21:17 pm »
it"s a copy of csp one , i bought it with a german man at the last european bug in , as i understand he was machining man ( sorry don't how to translate , in french we say "usineur"
he got more than 10 exemple at the back of his car
price was really good 150e
and i think fit better than the csp at shock absorber
i got 2 hard metal iece , and a friend weld them
look at this pic , he said you must weld all around if you want a hard piece
now i'm waitnig for the engine back home to test him in place in order to weld the lower piece
February 17, 2016, 04:15:49 am »
Oh I see, it seems great! Thank you for the infos.
Frenchy Dehoux
May 13, 2016, 07:37:49 am »
Nice project keep it coming with more pictures.
Jean Louis Dehoux ( Frenchy )
Doctor Detail ( Retired )
bzh67
May 15, 2016, 22:55:47 pm »
merci jean louis
try to put some pics tomorow but maybe not , cause my wife is pregnant and the baby maybe arrive in the few next days , maybe tomorow !!!!
celtik
May 16, 2016, 11:57:57 am »
Some picts for the engine.
