October 15, 2026, 10:36:02 am
New 94mm bore roller cam CB case/roller cam/Scat flange crank/flywheel
Topic: New 94mm bore roller cam CB case/roller cam/Scat flange crank/flywheel (Read 2476 times)
December 06, 2015, 14:19:08 pm »
1st
I have a New 94mm bore stroker clearanced CB aluminium case for sale, it has been modified for the Thrust set up and flange crank, also BMW type 4 to type 1 bearing mods, then modified for roller lifters and cam, finally it has been 6 studded all this was done by Geers engineering to a very high standard and includes the New roller lifters £1750
I also have a billet matching roller cam, turbo grind £350
Finally New 84mm scat billet flange crank with type 4 mains and chevy rod journals £1400
Flange flywheel £250
All available separately or as a package deal
this would be perfect for a JPM headed 94mm set up or similar, it will need more than normal 2 stud rocker set up on heads to control valve springs in my opinion
Pics shortly
