September 22, 2026, 09:01:48 am
Stock width beam, dropped spindles, but wide 5 discs?
Topic: Stock width beam, dropped spindles, but wide 5 discs? (Read 5619 times)
beetletom
December 08, 2015, 23:57:17 pm »
Am running a stock width link pin beam, with dropped spindles
But would like to get some decent brakes on it! I've seen csp do a kit, that the caliper mount bolts onto drum spindles , but do they work, if fitted to dropped spindles?
I'm also running stock wide 5 steels, so clearance shouldn't be a problem?
Re: Stock width beam, dropped spindles, but wide 5 discs?
December 09, 2015, 00:05:06 am »
I'd ask CSP.
beetletom
December 09, 2015, 20:44:39 pm »
Yes true.
Thought I'd ask on here as a lot of parts have been tried and tested by people
stait9
December 10, 2015, 00:54:27 am »
Hi
I'm running CB performance front discs with dropped spindles, however, the disc kits add about 3/4 of an inch back on each side so ended up with a narrowed beam. It's only 2 inches which means I can still run a sway bar that are readily available.
I believe one of the AirKewld kits doesn't add width so that could be an option -
http://www.airkewld.com/Stage-3-1949-65-VW-Beetle-Complete-Disc-Brake-Kit-p/4020.htm
Hope that's of help
Stuart
Chip
December 10, 2015, 07:04:51 am »
The Airkewld wide 5 pattern adds 3/8" to each side. Nice brakes though.
pupjoint
December 10, 2015, 15:01:25 pm »
i had same issues, resorted to a 3" narrowed beam, i personally hated how they ride.
changed back to stock width beam, dropped spindles, disc brakes, fuchs
andy198712
December 10, 2015, 18:12:51 pm »
Quote from: pupjoint on December 10, 2015, 15:01:25 pm
skinny tyres or no?
beetletom
December 10, 2015, 19:57:15 pm »
Thanks guys, airkewld kit is out of my budget, looks awesome though!
I'm getting the wheels banded on the inside, so I can run 175/55 continental's
