September 22, 2026, 09:01:42 am
| | |-+  Stock width beam, dropped spindles, but wide 5 discs?
Author Topic: Stock width beam, dropped spindles, but wide 5 discs?  (Read 5618 times)
beetletom
« on: December 08, 2015, 23:57:17 pm »
Am running a stock width link pin beam, with dropped spindles
But would like to get some decent brakes on it! I've seen csp do a kit, that the caliper mount bolts onto drum spindles , but do they work, if fitted to dropped spindles?
I'm also running stock wide 5 steels, so clearance shouldn't be a problem?
« Reply #1 on: December 09, 2015, 00:05:06 am »
I'd ask CSP.
beetletom
« Reply #2 on: December 09, 2015, 20:44:39 pm »
Yes true.
Thought I'd ask on here as a lot of parts have been tried and tested by people
stait9
« Reply #3 on: December 10, 2015, 00:54:27 am »
Hi
I'm running CB performance front discs with dropped spindles, however, the disc kits add about 3/4 of an inch back on each side so ended up with a narrowed beam.  It's only 2 inches which means I can still run a sway bar that are readily available.
I believe one of the AirKewld kits doesn't add width so that could be an option - http://www.airkewld.com/Stage-3-1949-65-VW-Beetle-Complete-Disc-Brake-Kit-p/4020.htm
Hope that's of help
Stuart
Chip
« Reply #4 on: December 10, 2015, 07:04:51 am »
The Airkewld wide 5 pattern adds 3/8" to each side. Nice brakes though.
pupjoint
« Reply #5 on: December 10, 2015, 15:01:25 pm »
i had same issues, resorted to a 3" narrowed beam, i personally hated how they ride.
changed back to stock width beam, dropped spindles, disc brakes, fuchs
« Reply #6 on: December 10, 2015, 18:12:51 pm »
skinny tyres or no?
beetletom
« Reply #7 on: December 10, 2015, 19:57:15 pm »
Thanks guys, airkewld kit is out of my budget, looks awesome though!
I'm getting the wheels banded on the inside, so I can run 175/55 continental's
