September 22, 2026, 02:29:45 am
| | |-+  Engine management for turbo drag beetle
Author Topic: Engine management for turbo drag beetle  (Read 15843 times)
numbnuts
« on: January 03, 2016, 09:05:58 am »
Hi guys, I am looking at getting an engine management system for a turbo drag beetle I am working on. We have just purchased the engine complete apart from the engine management system, any recommendations for an easy to set up system that has all of the inputs we will need and someone that can map it? Located in the Midlands uk
2854cc 1956 cal looker coming to this space shortly
andy198712
« Reply #1 on: January 03, 2016, 10:52:50 am »
Unless doing it your self (mega squirt) I'd speak to your chosen tuner and see what he's used to as some don't work on certain ecu's .....
Basti
« Reply #2 on: January 03, 2016, 18:36:46 pm »
due to my latest experience i would use a Fueltech FT 500.
Ver easy to fire up....but of course you need somebody to do the mapping right on the dyno.
Cheers,
Basti
- black 62 cal look beetle
- Pro Mod Race car
Christiano
« Reply #3 on: January 03, 2016, 20:53:31 pm »
Call Fueltech UK folks if you want get some more info about FT500
https://www.facebook.com/fueltechuk
Or you can throw your questions on this topic and I can answer you if they're tech questions Smiley
« Reply #4 on: January 04, 2016, 00:58:02 am »
 Grin
Is there a base model available that would suit using just a coil pack (eg like EDIS4), a 36-1 wheel or single crank pick-up (like modern bikes use), and 4 throttle bodies off a sportsbike?
Oh, and boost or bottle capable is a must.
Would it be easier to send it direct to Australia from Brazil rather than via Europe first?
You just never know how long it will take me to get sick of the 1584 I haven't even driven yet!  Cheesy
Christiano
« Reply #5 on: January 04, 2016, 01:31:05 am »
Hey
I'll start the reply backwards Smiley
There's a FT dealer in Australia, just not sure which company is taking care of that right now.
You can try get in touch with Fueltech USA and they'll give you a name since FT USA is responsible by Australia distribution as well.
As for the modules, the only modules with Boost and Nitrous control are FT400 and FT500, being FT500 the one that will give you more options to control both.
If you want a better boost control than the FT500 native one, there's a Fueltech BoostController module that will help you on this. FT400 boost control is too simple, I'd use it for some street applications only.
For the nitrous control, the FT500 native one is all you need. In the US we have ProNitrous guys (Jay Cox and other folks) running it and also Street Outlaws folks, like Daddy Dave in the Goliath.
« Reply #6 on: January 04, 2016, 02:06:07 am »
Thank you Christiano, much appreciated.
By boost/bottle control, I meant ignition map changes not electronic boost control.
I'll start G@@gling FT stuff and have a good look.
 Smiley
Christiano
« Reply #7 on: January 04, 2016, 12:10:18 pm »
Ah... So you can even go with a FT350 Smiley
You can take a look at their manuals and check if FT350 would be enough for what you need
http://www.fueltech.net/manuals
Turbo_Rich
« Reply #8 on: January 11, 2016, 09:30:27 am »
I use an Omex 600 ECU, made in the UK, great customer service easy to navigate round and loads of places will tune it. http://www.omextechnology.co.uk/
I can recommend http://www.advancedme.co.uk/ in Silverstone or Hi Tech motorsport http://www.hitechmotorsport.co.uk/ in Kidderminster for tuning.
Where about's are you and what are you building? I'm near Stratford On Avon
Good luck with it Smiley
spoolin70
« Reply #9 on: January 11, 2016, 18:07:04 pm »
+1 for Omex
I managed to get a 710 model pretty cheap. It was an older model with a black casing.  Spoke to Omex on the phone before committing and they said it was just packaged differently. They could run it through their diagnostic program to test its outputs and inputs and update the firmware to its latest version. I bought the ECU, sent it to them, got it tested with a report and returned within 10 days. Good service and helpful via email too.
My local mapper knows them too which was always a main concern. Having an ECU that nobody understands or can map would make things difficult !
Darren
andy198712
« Reply #10 on: January 11, 2016, 20:15:04 pm »
i use megasquirt and like it, its more DIY, in that you can mod it to have more features then any other, but unless you pay someone to do it, you'll need a bit of know how on diagrams and a soldering iron, i stick to the basic stuff! but works well, can tune its self with the right software.
IF your getting a tuner to do the tuning, its defy asking what they will tune though...
numbnuts
« Reply #11 on: January 16, 2016, 01:23:31 am »
Cheers for the replies guys, currently it has a 2387cc draw through turbo set up with Holley carb but have purchased an autocraft engine with fuel injection. We'll be racing this year, last year was not much success due to reliability issues hoping for better results.
Located in Solihull, cheers for the tips omex sounds good
« Reply #12 on: January 16, 2016, 09:18:08 am »
When in the UK you should perhaps also look into DTA. There is a few of us using DTA with success.
Best rgs
BB
numbnuts
« Reply #13 on: January 16, 2016, 13:17:24 pm »
Cheers, who are u using for mapping with dta?
« Reply #14 on: January 16, 2016, 15:20:39 pm »
Anyone with a PC can map a ECU. It is rather simple. My base map was made with the car bolted to Dyna Packs but I have changed the map so much over the years that there is hardly any data left from the base map apart from the ignition table.
Best rgs
BB
« Reply #15 on: January 16, 2016, 15:45:27 pm »
Alan at GAC knows DTA well and does mapping, he is near Aylesbury
numbnuts
« Reply #16 on: January 20, 2016, 21:14:23 pm »
