September 23, 2026, 03:02:51 am
What size Wheel studs for CB disc & flat 4 BRM's...?
Topic: What size Wheel studs for CB disc & flat 4 BRM's...? (Read 3803 times)
Kaferdog
January 13, 2016, 06:36:02 am »
Has anyone changed the wheel studs on CB wide 5 front hubs..? Mine have short studs and need to change them to accept Flat 4 BRM's . If anyone knows the right length I would Love to hear from you ..! ...Thanks
von-dart
Re: What size Wheel studs for CB disc & flat 4 BRM's...?
January 14, 2016, 21:43:47 pm »
Hi there,
I used 63mm long splined studs (overall length) It adds about 18mm. I'm using open ended nuts, but closed ends should be good if they're not too short.
Gary.
Last Edit: January 14, 2016, 22:18:39 pm by von-dart
Kaferdog
January 15, 2016, 10:24:58 am »
Thanks Gary.....I'll check it out..!
