May 20, 2026, 14:44:43 pm
Latest Member: mvptkfjb
| | |-+  Flat 4 BRMs with early drum brakes
Author Topic: Flat 4 BRMs with early drum brakes  (Read 5065 times)
Taylor
« on: January 16, 2016, 05:32:45 am »
Need some advice on fitting Flat 4 BRMs to a '64 bug with drum brakes.  I have only tried it once but the center cap hit the dust cover.  They fit fine on my '67 and I see plenty of people with them on early cars so there must be something I missed.  Do people run a different dust cover? No dust cover? Smash the dust cover? Some advice would be helpful.   Thanks
brmmark
« Reply #1 on: January 16, 2016, 10:06:01 am »
Have the same problem.  Still in the proces of having a spacer made to make some room for the dust cover. But didn't find the time to do so.
Chip
« Reply #2 on: January 16, 2016, 16:53:15 pm »
You could always try running 67 drums. There is a conversion bearing that allows you to run late drums/rotors on l/p spindles. The only thing I'm not sure about is the backing plate. I don't know if it's got the same bolt patten as an early one.
The bearing is an EMPI part. I'm currently running them on my 60 bug in order to run a rotor made for a later car. Works great!
Larry S
« Reply #3 on: January 16, 2016, 17:22:16 pm »
I am thinking that I saw some for sale that are made a little taller so they clear the older front drums.....
K-Roc
« Reply #4 on: January 16, 2016, 18:04:40 pm »
Smashing the dust cover will work
Taylor
« Reply #5 on: January 16, 2016, 18:34:43 pm »
You think so even with the speedo cable? I'm not opposed to it   Grin
K-Roc
« Reply #6 on: January 17, 2016, 01:17:08 am »
You may have to trim the tip of the cable as close to the circlip groove as possible.
j-dub
« Reply #7 on: January 19, 2016, 16:24:56 pm »
I don't have BRMs but in the past when I needed to clear aftermarket wheels I used something like these:
http://fisherbuggies.com/bugpack/vw-bug-beetle-rail-wheel-dust-caps
The ones I have were made by bugpack, i am sure you can still get them throught EMPI.
You do have to make your own hole for the speedo cable, I punched a hole with a small philips screw driver then used a bigger one to get the hole the right size and square
