November 02, 2026, 08:15:48 am
Body torque sequence
Topic: Body torque sequence (Read 6405 times)
vwhelmot
January 19, 2016, 10:09:32 am »
I need to properly bolt my body down to the pan to check door fit so I need the sequence to bolt it down safe without bending anything. I did see on here once that someone posted up a diagram showing the correct sequence to tighten down the bolts. Anyone help?
karl h
Re: Body torque sequence
January 19, 2016, 12:57:28 pm »
its german, but you get it:
http://www.cabshome.de/tipps/momente/aufbauskizze.jpg
if not, i can translate it for you
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
vwhelmot
January 19, 2016, 13:23:31 pm »
I cant make sense of that Karl
karl h
January 19, 2016, 22:42:00 pm »
1 torsion tube right/left
2 pan front right/left
3 front beam right/left
4 bolt near the shockmount right/left
5 bolts at the rear of the pan (behind the battery tray and oposite
6 rest of the bolts that go onto the heaterchanel
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
