April 25, 2024, 12:08:21 pm
LasseA
Off Topic
late bug fuch fitting?
Topic: late bug fuch fitting? (Read 5310 times)
Chubbygreen
January 28, 2016, 22:55:38 pm »
Hi guys just have a large problem at the moment bought a set of 5x130 fuch wheels 5.5 x 2 and 6 x2 so idea was to have 6's at the back and 5.5s at front, but the problem seems arch clearance, not only that but I will have to run adaptors and I have disks all round so yeh bit tricky unless someone has already overcome this, few ideas I had were.
Run early beetle axles to get the wheels under the arch, but unsure what the pre 67 beetles stud patterns were if they matched with Porsche ones or not, or get the drums redrilled and go back to drums if thats easier?
fairly new to this so please give me a chance and look forward for replies if possible cheers.
baz
Re: late bug fuch fitting?
January 31, 2016, 00:07:48 am »
You need to lose the adapters, i take it you have a late 4 stud pattern brake set up? If so the front can be changed to porsche pattern by replacing the discs with porsche pattern 5x130 pcd discs. The rear could be just as easy depending on what type of disc conversion you already have. Or you could switch to drums on the rear drilled to porsche pattern.
I will prevail.
Chubbygreen
February 02, 2016, 21:41:11 pm »
Cheers for the reply, who sells 5x130 pcd discs?
Jos
February 04, 2016, 03:13:33 am »
Take your pick, any vw parts house will have them.
Chubbygreen
February 04, 2016, 23:24:09 pm »
are these them
http://www.justkampers.com/22-2985-0-ball-joint-bolt-on-disc-brake-kit-blank-drilled-5-130-and-5-4-75-to-convert-drum-brakes-to-discs.html?
NoRiders
February 04, 2016, 23:42:12 pm »
I don't think those ^^^ would do as they mention a conversion kit and at £290 I think it is.
If you have stock VW front discs, you can replace them with these:
http://www.machine7.com/product.php?xProd=1631&xSec=981
Found these for the rear, but I'd be talking to M7 about your rears.
http://www.machine7.com/product.php?xProd=1664&xSec=1654
Do you know the disc conversion and what was used?
Chubbygreen
February 05, 2016, 19:56:55 pm »
Not sure will get back to you tommora when i find out.
Chubbygreen
February 06, 2016, 17:35:39 pm »
Does VARGA sound familiar?
Chubbygreen
February 07, 2016, 23:14:42 pm »
Someone must know, come on guys need some help here
baz
February 08, 2016, 21:35:17 pm »
It would help if you could post pics of your brake set up. Varga are standard replacement discs for post 68 bug, you can get them in porsche pcd pattern. Its your rear disc set up that may cause issues, nothing insurmountable though. More info needed in order for folk to help
I will prevail.
Chubbygreen
February 08, 2016, 22:55:04 pm »
Right cheers, will have to get around to doing that then cheers
