September 23, 2026, 09:20:57 am
inlet manifolds.
Topic: inlet manifolds. (Read 4965 times)
686 bus-boy
inlet manifolds.
February 09, 2016, 20:58:37 pm »
Looking for some advice and help please, im running 44idf weber carbs on what I presume are the generic inlet manifolds supplied in a carb kit, the velocity stacks I want to use are fouling on the rear of the body ( this is a beach buggy) I wondered if there are manifolds available that would move the carb forward around 25mm. Any help appreciated. Thanks.
Re: inlet manifolds.
February 09, 2016, 21:56:59 pm »
Are the manifolds straight or offset? Are they hitting on one side or both?
686 bus-boy
February 09, 2016, 22:03:01 pm »
They are offset, I have the same issue both sides.
February 10, 2016, 00:35:38 am »
You aren't going to find any manifolds that move them forward, sorry. Have your manifolds shortened, or use some short type 3 manifolds.
Curious, what velocity stacks do you want to use?
686 bus-boy
February 10, 2016, 08:24:44 am »
Thanks for your replies, I have 3.5" billet cb performance ones.
