October 28, 2026, 16:37:21 pm
Hanibal1
69 2276 efi bug
5
Topic: 69 2276 efi bug (Read 178585 times)
Re: 69 2276 efi bug
Reply #120 on:
September 07, 2019, 11:17:56 am »
28 deg of timing sounds too low to me. It should be able to handle 32 comfortably. It's not something daft like a sensor giving a false reading so the ECU is doing something it shouldn't?
baz
Re: 69 2276 efi bug
Reply #121 on:
September 07, 2019, 13:06:09 pm »
Last Edit: November 13, 2019, 08:33:54 am by baz
I will prevail.
baz
Re: 69 2276 efi bug
Reply #122 on:
September 07, 2019, 16:35:58 pm »
Last Edit: November 13, 2019, 08:35:13 am by baz
I will prevail.
andy198712
Re: 69 2276 efi bug
Reply #123 on:
September 07, 2019, 17:12:21 pm »
Could be a few teeth out though maybe? Or did you deffo line up the dots?
And the slot for the oil pump lines up with the dot on the cam gear too....
Can going flat? Can rough check it with a ruler if you don’t have a dti handy
baz
Re: 69 2276 efi bug
Reply #124 on:
September 07, 2019, 17:34:49 pm »
Last Edit: November 13, 2019, 08:32:57 am by baz
I will prevail.
Re: 69 2276 efi bug
Reply #125 on:
September 07, 2019, 20:07:03 pm »
Are you getting full throttle on the linkage? I know it's an obvious one but worth a check
vwhelmot
Re: 69 2276 efi bug
Reply #126 on:
September 07, 2019, 20:22:01 pm »
I’m not sure it sounds right. Might be just me but the exhaust note doesn’t sound as it should.
baz
Re: 69 2276 efi bug
Reply #127 on:
September 07, 2019, 20:36:52 pm »
Quote from: leec on September 07, 2019, 20:07:03 pm
Yep double checked that today.
I will prevail.
baz
Re: 69 2276 efi bug
Reply #128 on:
September 07, 2019, 20:41:19 pm »
Last Edit: November 13, 2019, 08:32:01 am by baz
I will prevail.
Re: 69 2276 efi bug
Reply #129 on:
September 07, 2019, 20:52:44 pm »
Sound reminds me when I got two plug leads round the wrong way.
baz
Re: 69 2276 efi bug
Reply #130 on:
September 07, 2019, 20:59:40 pm »
Last Edit: November 13, 2019, 08:31:29 am by baz
I will prevail.
Re: 69 2276 efi bug
Reply #131 on:
September 07, 2019, 21:11:29 pm »
I will stop suggesting, I forget you have all this fancy fuel injection stuff I know nothing about
Re: 69 2276 efi bug
Reply #132 on:
September 07, 2019, 21:32:08 pm »
Baz
does sound weird, almost a banging/knocking noise, and if cam is going flat it goes on nose not base so doesn't affect lash until its totally fucked and starts to destroy lifters
baz
Re: 69 2276 efi bug
Reply #133 on:
September 07, 2019, 21:38:13 pm »
Last Edit: November 13, 2019, 08:30:59 am by baz
I will prevail.
baz
Re: 69 2276 efi bug
Reply #134 on:
September 07, 2019, 21:45:47 pm »
Last Edit: November 13, 2019, 08:30:28 am by baz
I will prevail.
baz
Re: 69 2276 efi bug
Reply #135 on:
October 21, 2019, 09:41:42 am »
Last Edit: November 13, 2019, 08:29:54 am by baz
I will prevail.
Re: 69 2276 efi bug
Reply #136 on:
October 21, 2019, 11:10:17 am »
Glad you got to the bottom of the problem! Were you a tooth out on the cam gear? Looks great, and 155 at the wheels is still 185ish bhp at the flywheel, which I'd be happy with, especially with the driveability of the modern tech you've chucked at it!
baz
Re: 69 2276 efi bug
Reply #137 on:
October 21, 2019, 11:57:44 am »
Last Edit: November 12, 2019, 09:08:48 am by baz
I will prevail.
Re: 69 2276 efi bug
Reply #138 on:
October 21, 2019, 13:35:31 pm »
Well done Baz,
Was thinking about this a few days ago wondering if you had found out/sorted the issue.
As ever, car looks great.
Lee
baz
Re: 69 2276 efi bug
Reply #139 on:
October 21, 2019, 16:34:47 pm »
Thanks Lee great to finally have it done just hoping for lots of dry weather over the winter so I can use it.
I will prevail.
baz
Re: 69 2276 efi bug
Reply #140 on:
November 09, 2019, 14:15:08 pm »
Last Edit: November 12, 2019, 09:08:09 am by baz
I will prevail.
baz
Re: 69 2276 efi bug
Reply #141 on:
November 13, 2019, 08:33:16 am »
I will prevail.
Re: 69 2276 efi bug
Reply #142 on:
November 25, 2019, 11:07:14 am »
Baz,
Are you running stock IRS or narrowed arms?
I've got a set of JGE burners with 205/70's on and wondered if they would fit a long axle 70 bug with stock fenders
Lee
baz
Re: 69 2276 efi bug
Reply #143 on:
December 07, 2019, 18:09:08 pm »
Quote from: leec on November 25, 2019, 11:07:14 am
Baz,
Lee
Sorry for late reply Lee, I'm running standard arms. Caps won't fit without grinding axle ends, dunno if swing axle same but assume they are. I had threads extended on stub axle and grinded ends off so caps would fit.
I will prevail.
Re: 69 2276 efi bug
Reply #144 on:
December 10, 2019, 18:51:01 pm »
Thanks for the info Baz,
Lee
5
