September 22, 2026, 07:09:13 am
| | |-+  Novice needs tire advice
Pages: [1] 2 Print
Author Topic: Novice needs tire advice  (Read 21505 times)
Deadzed13
« on: February 27, 2016, 13:11:41 pm »
Hi. I'm about to Give my late Beetle the Cal Look treatment. I've got myself a nice set of BRM's front 4.5 rear 5.5. I plan to stick Michelin XZX 145 x15 on the front. But it's the rear that's got me scratching my head. The wheels are offset ET:15, and I'm guessing that a 205/70r 15 might be a big ask. So I'm thinking 185/70r 15. I've been look at Michelin XWX or the slightly cheaper Avon CR6ZZ. I'm no mechanic and I'm thinking my Beetle being a 1991 Mexican it will be IRS. Do you think I'll have clearance issues with 185's? They cost a fortune so I wants to get it right. Any advice would be a big help. Thanks guys.
pWolf
« Reply #1 on: February 27, 2016, 13:35:08 pm »
I think a 205/65 tire would be great.
Deadzed13
« Reply #2 on: February 27, 2016, 17:19:09 pm »
Agreed, but don't think it will fit due to the irs axle length.
« Reply #3 on: February 27, 2016, 18:45:03 pm »
Maybe check 185R15 tires, they would have a wall height closer to the 205/70 you want, but narrower for IRS clearance.
vdanielw
« Reply #4 on: February 27, 2016, 19:21:14 pm »
A friend of mine has a 90's Mexican bug and it is swing axle.  Looking for the raked looked I'd say 195/65(or70) or the 205 mentioned previously.
Deadzed13
« Reply #5 on: February 27, 2016, 19:39:04 pm »
That's what I'm thinking. I'm not interested in dropping the wheel into the arch. I'm looking for that Arse end up, deep race tyre look.
Deadzed13
« Reply #6 on: February 27, 2016, 19:41:28 pm »
Kind of got my heart set on a 70r. I think the axles are too long for a 205, otherwise that would be my first choice.
baz
« Reply #7 on: February 27, 2016, 20:00:05 pm »
This is a 195/60 on a 5.5 inch et 15 wheel. Swing axle same as standard mexi bug
I will prevail.
Deadzed13
« Reply #8 on: February 27, 2016, 20:35:37 pm »
Nice
Vdubchef
« Reply #9 on: February 27, 2016, 21:13:49 pm »
Sorry to loan the topic but this fits my question too. Got a -68 bug with long axles and 4x130 centerline reps on 15x5,5 with small offset( 10-20mm?) Was gonna fit the rear wheels with some 205/70 rubbers. What do you guys think, gonna have clearance problems? Ass is gonna be up all the way for some good rake.
« Last Edit: February 27, 2016, 21:26:09 pm by Vdubchef » Logged
baz
« Reply #10 on: February 27, 2016, 21:33:14 pm »
205s on the car above would stick out another 5mm ie half the extra width of tire compared to a 195 tire.
205s on a 10et wheel would stick out 10mm more than the pic above, 5mm for the tire and 5mm less et.
205s on a 20et wheel would sit in same place as the pic above, the extra 5mm of tire stick out would be evened out by the 5mm greater et
I will prevail.
Deadzed13
« Reply #11 on: February 27, 2016, 22:24:05 pm »
thats interesting Baz. I think the tape measure will have to come out for this one. I'm betting 185/70r will be a nice snug fit. I think the 205 will fowl the arch.
[/quote]
« Reply #12 on: February 28, 2016, 01:52:20 am »
195/70's?
Paul Bahnstormerz
« Reply #13 on: February 28, 2016, 12:08:24 pm »
195 was the biggest I got under a long axle'd bug
Deadzed13
« Reply #14 on: February 28, 2016, 12:29:40 pm »
Was that a 65r or 70r?
« Reply #15 on: February 28, 2016, 12:57:55 pm »
Its the wheel choice that messes it up, this is a "long axle" IRS car at close to stock height with 205/70/15 on and clears easily both sides, inner and outer. I would try a tyre shop to see if they have a old scrap 195/65[ or similar to give you idea] they could fit on your wheel so you can check fit on the car before spending out on new tyres Smiley
« Reply #16 on: February 28, 2016, 13:19:45 pm »
That's stock width IRS Richie?
No mods to trailing arms or anything?
Lee
« Reply #17 on: February 28, 2016, 13:21:37 pm »
Lee
Yep totally stock width Smiley
Vdubchef
« Reply #18 on: February 28, 2016, 13:55:22 pm »
Whats the offset on those wheels richie?
« Reply #19 on: February 28, 2016, 13:57:42 pm »
ET30 Smiley
Vdubchef
« Reply #20 on: February 28, 2016, 14:04:03 pm »
I have now 195/60 on those same centerline repros, and one outer click lowered. They fit without problems. Gonna lift it to stock thou on the rear.
Deadzed13
« Reply #21 on: February 28, 2016, 15:58:06 pm »
Dude! That's genius! I didn't think of doing the obvious. I'll be down the scrap yard tomorrow. Thanks  Wink
56BLITZ
« Reply #22 on: March 01, 2016, 03:42:04 am »
I just put a pair of 205/65r15 Continentals on the back of my '70 . . . Late-style 15X6 Porsche (Fuchs) alloys . . . they fit fine and look nice!
Jesucristo es mi Seņor y Salvador!
Deadzed13
« Reply #23 on: March 01, 2016, 21:05:44 pm »
Long axels?
56BLITZ
« Reply #24 on: March 02, 2016, 19:29:39 pm »
Long axels?
Sorry . . . USA VWs got IRS starting in 1969 . . . I do not know how the IRS "track width" compares to that of long swing-axles.
Martin S.
« Reply #25 on: March 02, 2016, 19:41:10 pm »
IRS track and late Swing track are the same at 53.1" while early Swings are 50.7" track.
Erlend / bug66
Global Moderator
SCC Event
« Reply #26 on: March 02, 2016, 20:58:01 pm »
ET30 Smiley
Same wheels and 215/65 M&H DOT slicks is as big as you can go on long axles / IRS.
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
neil68
« Reply #27 on: March 03, 2016, 05:54:54 am »
Yes, Mexican Beetles came from the factory with the late "long swing axle".
I have 215/65 M&H's on my '68 Beetle, but that only worked well after I switched to short swing axles.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
« Reply #28 on: March 03, 2016, 17:19:50 pm »
Verrrrry nice Richie!
Those wheels are made here: ÅSV = Hydro Årdal and Sunndal Verk
-BB-
Stevo_L
« Reply #29 on: March 05, 2016, 22:28:26 pm »
with ET15 and long axles i would say 185 is max under stock fenders.
i have 185R15 on long axles ET25..
Pages: [1] 2 Print
