September 22, 2026, 05:04:52 am
| | |-+  Adustable spring plates and tyre clearance
Author Topic: Adustable spring plates and tyre clearance  (Read 11775 times)
vwhelmot
« on: March 17, 2016, 12:25:09 pm »
As in the title, am I going to have issues with my sway away rear adjustable spring plates ( short axles) and dot racemaster 215 mounted on OG gas burners?   I have some spacers but just wanted an idea if I`m pissing against the wind with this set up?
« Reply #1 on: March 17, 2016, 13:36:58 pm »
What brake set up are you using?
« Reply #2 on: March 17, 2016, 14:07:35 pm »
As I remember the tire gets into the body mount before the spring plate adjuster.
vwhelmot
« Reply #3 on: March 17, 2016, 15:48:49 pm »
I'm using airkewld rear discs. I'm pretty sure they don't increase the rear track.
Bill Schwimmer
« Reply #4 on: March 17, 2016, 17:31:46 pm »
Try it & see, I have the same tires & spring plates, t3 drums & BRMs, So I have a bit more offset. You can take a bit off the adjuster block, that will gain a little. Spacers will be your friend.
    Eddy Merckx
« Reply #5 on: March 17, 2016, 17:55:53 pm »
Yes, we had to put a spacer on Jo's ragtop with reg spring plates as they rubbed with those wheels and tyres
vwhelmot
« Reply #6 on: March 17, 2016, 20:48:21 pm »
No worries, I've got a pair of spacers to try when it's time. Thanks everyone:)
Richierich56
« Reply #7 on: March 18, 2016, 11:30:31 am »
I'm on Type 3 drums running 205/65/15 on Gasburners and ended up having to use 13mm spacers. Took a fair bit off the adjuster step first aswell as Bill mentioned. Good luck!!
karl h
« Reply #8 on: March 18, 2016, 16:08:50 pm »
i would use some porsche 944 rear adjustable springplates, no clearence issues with M&H Dots even with 1" narrowed trailing arms and (your) burners on 944 rear brake hubs
« Reply #9 on: March 18, 2016, 16:59:25 pm »
On a swingaxle car? are they long enough?
« Reply #10 on: March 19, 2016, 11:38:54 am »
Nope.  Karl must've forgotten the original Q was about swing.
I've also got 944 adjustable spring plates on my IRS car.  TAs narrowed 34mm/side to fit 8" Fuchs.
folkevogn
« Reply #11 on: March 21, 2016, 21:30:44 pm »
Hope i'm not hijacking your tread vwhelmot. I have simular concerns at the moment so I tought it would be silly to start another tread😊
How much clearence do you need? I've just fitted a Phoenix 7x26x15 on at Flat4 BRM to check tire clearence. It's a 1963 swing axle. I have 8mm between the tire and ajuster, is that enough? Can I grind 2-3mm of the ajuster to get better clearence?
Mvh
Folke Vogn
11.96 @ 180kmh - SCC 2013 Grin
vwhelmot
« Reply #12 on: March 21, 2016, 22:08:07 pm »
I would have thought that 8mm would be enough but if you can get more clearance then I would.
folkevogn
« Reply #13 on: March 21, 2016, 22:41:03 pm »
Thanks, think i will try to grind 2mm of the ajuster to be sure Smiley
karl h
« Reply #14 on: March 22, 2016, 08:29:30 am »
Sorry, forgot you have swing.
But the system is transferable to swing with modifying the stock springplates
