September 23, 2026, 04:03:19 am
Jaycee pro fuel inlets
Topic: Jaycee pro fuel inlets (Read 4881 times)
chez2165
March 22, 2016, 22:00:54 pm »
I am just about to fit these to my IDA's, do you need to remove the filter before fitting the Jaycee inlets or does it stay in place.
I already have an additional fuel filter inline
neil68
Re: Jaycee pro fuel inlets
March 23, 2016, 19:34:35 pm »
I removed the filter from my IDA's, as the Jaycee top fitting protrudes downward much too close to the filter. It just looks like there might be a flow disturbance (with the filter in place).
If you are stepping up to 3.0 mm needle valves, then you may want to enlarge the IDA inlet as well.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
March 24, 2016, 00:06:18 am »
You must remove the stock screen. With it in place, it blocks all flow.
You should also drill the passage leading to the inlet valve to at least 4mm.
