September 22, 2026, 21:11:58 pm
Race car hinge pins
Topic: Race car hinge pins (Read 10803 times)
Race car hinge pins
March 27, 2016, 15:16:33 pm »
Hi guys,
Had a quick google but nothing really found...
I want to run my steel type 3 doors with original hinges but would like to use some sort of quick release hinge pins. The aim is that I can remove the doors easy if I need to by just removing the hinge pin and leaving the hinge attached to a post, does that make sense?
Any ideas?
Lee
Paul Bahnstormerz
Re: Race car hinge pins
March 27, 2016, 15:35:56 pm »
Tap one end of a rod and loctite a rivnut to one end, fit the pin, drill a hole for split pin to lock in place. The rivnut has a nice flange to rest against the hinge plates and gives you something to pull on
March 27, 2016, 15:56:58 pm »
Nice idea, thank you
March 27, 2016, 16:19:30 pm »
Google (or eBay) 'pip pins'... Quicker and more convenient than using rods with separate split pins, etc. Plenty of designs available:
spanners
March 28, 2016, 12:26:43 pm »
You all must have gold cards,
some gorgeous kit out there right enough, but I only use shop bought to go quicker if I can't DIY my own solutions, I use Allen cap screws on nyloks, available in TI and ally if you must pair off grams.
Best regards, spanners.
dragvw2180
March 28, 2016, 13:36:05 pm »
Me , I am a cheap ass , I use long bolts which I remove the threaded part from and reshape and polish the bolt head . I leave the new pin a 1/4 inch longer than the hinge that way I can push the pin up for removal, has worked well for me. My race partner John has a cotter pin in his also but again mine have never fallen out without them. Hope this helps, Mike
stussyrich
March 28, 2016, 15:28:56 pm »
I'd say you don't need a removable pin at all. just modify the original hinges.
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
March 28, 2016, 16:29:51 pm »
Quote from: stussyrich on March 28, 2016, 15:28:56 pm
Interesting. In what way?
Lee
stussyrich
March 28, 2016, 16:53:12 pm »
Quote from: leec on March 28, 2016, 16:29:51 pm
Lee
can't find any pics but you just cut the top section of the hinge off the car side and leave the original pin in. then open up the hole in the hinge section on the door side to allow it to slide freely over the old pin.
simple.
March 28, 2016, 17:36:34 pm »
Lee
Push pin out, machine top half of pin slightly undersize so it slips into top half of hinge easily, then push pin back in again
spanners
March 28, 2016, 18:07:45 pm »
That's the thing of this forum, more tinkers than other forums, many solutions hitting the spot, my rallycross cars of the '80s were pared to the bone, the heavy hinges were binned and replaced with ally angle, only the joy (stupidity) of youths recklessness allowed me to run in a contact motor sport with skeletal doors and turbo power
March 28, 2016, 18:30:20 pm »
I used steel rod, cut with 5mm over at each end. Welded a washer on the top, then spun the pin in a drill while using a grinder to shape a mushroom head out of the weld. Tapered the bottom slight and drilled a hole for a split pin. The only time I ever took the doors off was when I was fitting the new roll cage - so you have to ask yourself, how useful exactly are lift off doors?
stussyrich
March 28, 2016, 18:51:42 pm »
Quote from: Neil Davies on March 28, 2016, 18:30:20 pm
ever tried pushing / steering a car with non opening windows into a small workshop. or even trying to work on interior of the car in a garage with the doors on.
There is loads of reasons to have them removeable.
