October 07, 2026, 02:37:09 am
352314 Posts in 28957 Topics by 6926 Members
Latest Member: Chakalives
| | |-+  Duff keepers?
Author Topic: Duff keepers?  (Read 14367 times)
Lukej
« on: March 27, 2016, 19:15:24 pm »
Quick question guys,
New valves
New Scat Retainers
New Scat Keepers
They look like scrap to me... Impossible to pull the keeper fully into the grooves to get the retainer sat where it should...
I'm well aware that most parts need fettling in some form to get them to fit but with these I cannot see how they can be fixed... Is there another brand I should be going for or did I just get a bad batch?
I'll speak to the supplier after the bank holiday (unless he recognises me on here Wink)
Thoughts much appreciated Smiley
Luke
« Reply #1 on: March 27, 2016, 19:25:29 pm »
How do the  keepers fit in retainer with out valve? yes or no? something not right there for sure, what diameter valves are they?
Lukej
« Reply #2 on: March 27, 2016, 19:34:50 pm »
They fit into the retainers fine without a valve but you can see the bottom grooves are misaligned when doing so... I did manage to get a couple of them seated correctly but then had to use a tiny screwdriver to prize them apart to get them off.
Lukej
« Reply #3 on: March 28, 2016, 11:28:39 am »
42x37 valves, 8mm stems.
Kinda difficult to tell but you can just about make out the grooves not lining up... Scrap?
« Last Edit: March 28, 2016, 11:40:15 am by Lukej » Logged
« Reply #4 on: March 28, 2016, 16:43:54 pm »
how many are messed up? odd one or?
Lukej
« Reply #5 on: March 28, 2016, 18:40:12 pm »
I pulled 8 out to do 1 head and didn't get a pair that sat well. Not that they needed gapping at all, they wouldn't sit well enough to get even close to closing up.
I pulled a couple more out of the bag to try and get a good pair to get an accurate installed height so I can get the spring shims ordered. I found enough for 2 valves...
« Reply #6 on: March 28, 2016, 19:49:07 pm »
And here I thought Duff only made beer.
Lukej
« Reply #7 on: March 28, 2016, 19:56:33 pm »
Looks like they tried to fire a few keepers out on the night shift Cheesy
« Reply #8 on: March 28, 2016, 21:35:27 pm »
 Cheesy or Monday morning before their 3rd coffee!
Colletts would be the same as most other parts wouldn't they, all out of the same place just different packaging?
Does anyone make their own really nice ones? SI Valves? Manley?
(I'm just curious).
Lukej
« Reply #9 on: March 28, 2016, 21:47:15 pm »
So what is the solution? Dig some stock VW ones out? Or did I literally just get a shitty batch?
« Reply #10 on: March 28, 2016, 21:56:35 pm »
If it was my little 1600 I'd start digging........ Wink
Lukej
« Reply #11 on: March 29, 2016, 05:45:52 am »
What if it was your 2276 with an 86b?
Dougy Dee
« Reply #12 on: March 29, 2016, 13:19:11 pm »
For most items I trust used VW over new CRAP. Just saying...
OK. Now that the thought train has left the station....
Have you fitted old VW keepers to your new  valves?
Or new keepers to old valves?
Possibly your issues are not isolated to one item...
Lukej
« Reply #13 on: March 29, 2016, 15:45:18 pm »
Stock VW fit snug.
« Reply #14 on: March 29, 2016, 16:18:34 pm »
Stock VW fit snug.
If I were using those I would grind them on sides a little, you don't want them to touch
Lukej
« Reply #15 on: March 29, 2016, 17:28:10 pm »
Yeah just tried them to rule out issues with the valves or retainers...
Are stock keepers fit for the job or do I need some aftermarket ones?
You're Richie from RJVolks aren't you?
« Reply #16 on: March 29, 2016, 18:33:19 pm »
Yes I am, and I never tried stock ones with dual springs so don't know for sure
dragvw2180
« Reply #17 on: March 30, 2016, 14:34:11 pm »
 Has anyone on here had a stock keeper that was clearanced properly ever fail ?  I have been lucky I guess , I have never seen a failure that I can say were caused by the properly clearanced keeper failing even with my K800 springs and retainers. Mike McCarthy
« Reply #18 on: April 01, 2016, 16:55:20 pm »
New valves
New Scat Retainers
New Scat Keepers
Luke
Well I am really confused, I received the valve locks back today from Luke and test fitted them all to a stock VW valve and used the Scat retainer and they all fit fine, this is just one of them in my picture, I have no idea why they fit so badly to your valves but they seem good to me  Huh
Lukej
« Reply #19 on: April 01, 2016, 19:09:31 pm »
How odd, just checked the valves out. They're branded 'SI' never heard of them... They're brand new from Roy at Mofoco... Are these a decent brand? Should their grooves follow the norm and fit these keepers?
max Der Bahnstormerz
« Reply #20 on: April 06, 2016, 18:47:39 pm »
can we see a pic of one keeper sitting in the valve grooves and a pair of keepers in the retainer with no valve?
My guess is that they may need a little more grinding or the valve grooves aren't deep enough
