October 04, 2026, 15:20:19 pm
Mallory unilite distributor 4554101 advance??!!
Topic: Mallory unilite distributor 4554101 advance??!! (Read 5089 times)
chateau la fete
March 31, 2016, 20:50:11 pm »
I have adjusted my mallory to 20 in the curve and 10 degrees static with grey/grey springs
2332 with IDA's and running a mallory CDI with mallory coil
I am getting a flat spot/hesitation at around 4500/5000 rpm
Any thoughts??!!
kever65
Re: Mallory unilite distributor 4554101 advance??!!
April 02, 2016, 07:31:47 am »
Do you have air fuel readings? Could be a fuel issue
chateau la fete
April 04, 2016, 13:58:50 pm »
Fuel supply is good, IDA's have been rebuilt as well.....
Maybe a timing issue??!!
henk
April 04, 2016, 14:56:55 pm »
20 in the curve,do you mean then that it have only 20 degrees advance instead of 28-32 degrees advance?
Henk!!!
chateau la fete
April 04, 2016, 15:03:03 pm »
20 degrees mechanical advance (internal of the mallory distributor) and 10 degrees static timing, so 30 degrees total advance
