October 12, 2026, 13:34:25 pm
| | |-+  Help needed, my swingaxle eats wheelbearings.....
Author Topic: Help needed, my swingaxle eats wheelbearings.....  (Read 9640 times)
Eddie DVK
« on: April 03, 2016, 20:07:31 pm »
Ok like the title says, my car eats wheelbearings... Angry
The last bearing lasted 300km / 200 miles, the one before about 1000km..
The axle isn t lowered, standard height.
What can cause them to have end play that fast....?
I don t know anymore  Cry
Regards edgar
oh it is only the passenger side (right Side)
« Last Edit: April 03, 2016, 20:12:17 pm by Eddie » Logged
Regards Edgar
« Reply #1 on: April 04, 2016, 15:29:21 pm »
Maybe a bent axle?
Eddie DVK
« Reply #2 on: April 04, 2016, 16:39:11 pm »
Ok could be, can I somehow measure that or would it be visable by eye?
I have had this axles for years in the car, so what could have caused it to bend... maybe stoplight racing...?
Regards Edgar
« Reply #3 on: April 04, 2016, 17:47:22 pm »
Probably more of an alignment issue -- pull measurements from center cap to center cap on both sides and see if they are the same -- also measure the distance across from the fronts of both rear tires and the same spot on the rears of the tires and see how those compare.
Eddie DVK
« Reply #4 on: April 06, 2016, 08:58:42 am »
Just had it aligned last year, so don t think that is it... But when I renew the bearing I will do that again.
Regards Edgar
Eddie DVK
« Reply #5 on: April 06, 2016, 08:59:40 am »
Nobody else has suggestions?
Regards Edgar
« Reply #6 on: April 06, 2016, 16:03:59 pm »
If it gets oil there must be something else wrong..
I d suspect a bent shaft
dragvw2180
« Reply #7 on: April 06, 2016, 16:19:34 pm »
 There are multiple reasons for bearing failure , lack of lube , wheels with too much offset , low quality bearings, ect...  The problem is that you are only having it on one side multiple times. If it were me I would use the best quality bearing  ( call Rancho for bearing )  I could find and replace the axle tube assy with another one , then realign it as already suggested. Mike McCarthy
