September 24, 2026, 21:40:47 pm
| |-+  For sale!
| | |-+  DPR 82mm crank and flywheel. Kennedy stage 2 plate. CB 5.4 race rods
Author Topic: DPR 82mm crank and flywheel. Kennedy stage 2 plate. CB 5.4 race rods  (Read 3845 times)
baz
« on: April 05, 2016, 21:22:37 pm »
Have an almost new DPR crank and lightened flywheel with 11/32 dowel pins, crank only used for 2 hours on dyno, was standard mains and journals but needs grinding on journals at least. £250 as is or £375 after re-grind
Kennedy stage 2 pressure plate,  again 2 hours old. £60
cb race rods 5.4, again 2 hours old, I'm switching to 5.5s. £175
Will do a deal on the whole package for £450 as is or £575 after re-grind
Parts are in uk west london area
I will prevail.
Jay Aldred
« Reply #1 on: April 06, 2016, 07:05:02 am »
Why does it need a re grind ?
baz
« Reply #2 on: April 06, 2016, 13:06:04 pm »
The engine locked up during that dyno session, oil starvation to the rods caused no 2 to lock up. Theres a thread in pure racing about it.
Edit. It was a soft lock up,  went at idle and there is absolutely no heat discolouration to the rods or crank.
I've bought new replacement crank as the wait for a re grind was taking the piss.
« Last Edit: April 06, 2016, 17:55:24 pm by baz » Logged
I will prevail.
baz
« Reply #3 on: May 06, 2016, 15:20:53 pm »
Crank flywheel and clutch still here. Also got nos vw main and rod bearings available to suit first undersize.
I will prevail.
