October 13, 2026, 15:59:52 pm
Carrillo H beam rods, 94mm bore magnesium stroker case, 135/15 nankang tyres
Topic: Carrillo H beam rods, 94mm bore magnesium stroker case, 135/15 nankang tyres (Read 7374 times)
April 09, 2016, 10:15:39 am »
For sale New set of 95mm thickwall cylinders
5.8 Carrillo H beam rods, as new, been used to mock up but nothing more £750
New Magnesium case, 94mm bore full flowed and stroker clearance, has been align bored 1st size over as main bearing tunnel was not 100% from new, work done by Rimco 10 years ago, been on shelf since £700
Last Edit: April 26, 2016, 13:20:10 pm by richie
Re: 95mm Thickwall cylinders type 1
April 09, 2016, 19:16:42 pm »
Who made these? Do you know the OD?
April 09, 2016, 19:35:16 pm »
Quote from: Zach Gomulka on April 09, 2016, 19:16:42 pm
I will measure them in morning
April 10, 2016, 16:32:10 pm »
Here you are Zach
April 11, 2016, 05:45:46 am »
Wow, those are thick!
Jeff68
April 12, 2016, 13:55:47 pm »
Richie are these the JPM cylinders? The walls are very thick. These look really nice.
Doktor
April 14, 2016, 15:14:12 pm »
What pistons can be used with these cylinders ?
dr.aircooled
April 14, 2016, 18:16:40 pm »
Quote from: Jeff68 on April 12, 2016, 13:55:47 pm
Hi Jeff, no they are not, I think his are a lot more money
Quote from: Doktor on April 14, 2016, 15:14:12 pm
I don't know anything off the shelf, only some special order from any good piston supplier
ottobros
April 21, 2016, 22:42:39 pm »
PM send
April 22, 2016, 20:05:34 pm »
Cylinders Sold
Last Edit: April 24, 2016, 16:08:36 pm by richie
ottobros
April 24, 2016, 12:55:06 pm »
Thanks Richie
Re: 95mmc ylinders , Carrillo H beam rods, 94mm bore magnesium stroker case
April 24, 2016, 16:08:50 pm »
More parts added
Re: Carrillo H beam rods, 94mm bore magnesium stroker case, 135/15 nankang tyres
April 26, 2016, 13:21:12 pm »
Nice pair of 135/15 nankang tyres, virtually new, used as front tyres on drag car for 10passes only
£50
