November 03, 2026, 07:14:30 am
| | |-+  waterboxer case
Author Topic: waterboxer case  (Read 14077 times)
Bad bug
« on: May 04, 2016, 01:17:12 am »
Good night Guys,
Need to know if anyone has through bolted a waterboxer case.
« Reply #1 on: May 04, 2016, 06:03:24 am »
Good night Guys,
Hi Bad Bug,
Not actually the answer you are looking for but I have to ask, is there actually any need to through bolt a WBX case? We have guys that push 1000hp using a WBX case without through bolting it.
-BB-
Bad bug
« Reply #2 on: May 04, 2016, 23:32:28 pm »
Yeah is that the skinne beetle.
« Reply #3 on: May 05, 2016, 08:13:23 am »
Yes indeed it is and that says something about the quality of that case. VW used all their knowledge from the mag case and improved all the weak points and made it a lot stronger. It is a very good case!
-BB-
Bad bug
« Reply #4 on: May 05, 2016, 09:02:41 am »
I am thinking about using it in a 4 inch bore engine i want to do but there are other considerations before i go ahead with purchasing stuff like if there will be adequate cooling between the cylinders for this daily driven engine.
Does anyone know if Skinne had done a all t4 main on the 86mm crank in his engine.
« Last Edit: May 05, 2016, 09:23:28 am by Bad bug » Logged
Bad bug
« Reply #5 on: May 07, 2016, 15:34:25 pm »
282 views nobody has anymore information to add to this discussion. Guys, need to know what skinne did with the waterboxer block for his engine.
max2919
« Reply #6 on: May 07, 2016, 18:00:26 pm »
I have heard that Skinnes WBX has Chrysler? mains.
VW 57 Ghia RLR 2919cc TURBO!
Porsche 356A Coupe replika.
« Reply #7 on: May 07, 2016, 20:12:17 pm »
Pauter rods and ford cleveland 2.75 journals.
On behalf of Tor O. Skinne:
-BB-
Bad bug
« Reply #8 on: May 08, 2016, 00:04:07 am »
Max is that anything close to the 411 mains.
Bad bug
« Reply #9 on: May 08, 2016, 00:40:54 am »
-BB-
Seems like the Chrysler RB bearings ( 2.75mm ) would be a nice match for a 411 all main crank. Will have to check on the width of the bearing. Has anyone other than skinne done this to there block.
max2919
« Reply #10 on: May 08, 2016, 11:42:02 am »
-BB-
Is it the same spec as the Pauter bigblock use?
Bad bug
« Reply #11 on: May 08, 2016, 15:42:48 pm »
-BB-
Max as i said earlier and now confirmed by pauter site chrysler bearing is similar to the t4 mains. See section in green.
90-1000-C   Pauter Super Pro Big Block - Chrysler
Main journal bores accept OEM Chrysler bearings which fit the VW Type IV main journal cranks, with slight modification to thrust width.
5pc 356-T6 aluminum block assy with bolts, nuts.  Specify bore size and cylinder stud pattern desired    (studs not included).
max2919
« Reply #12 on: May 08, 2016, 16:17:22 pm »
Bad bug
« Reply #13 on: May 08, 2016, 16:52:44 pm »
Max there is more. We know now that the chrysler main is a 2.75 similar to the t4/411 vw engine but the bearing thickness is a bight more. This would mean then that it's not truly a direct drop in and the case would need boring for this.
I was on youtube this morning watching a chrysler build and the guy quoted the thickness of the chrysler bearing as .0934 inches.
« Reply #14 on: May 09, 2016, 07:49:54 am »
Just had to post this picture;
- WBX case
- WBX AMC heads
- IRS
- Porsche G50 5 speed H pattern gearbox
- Original VW pan
8.02 - 180mph
-BB-
« Last Edit: May 09, 2016, 07:53:08 am by BeetleBug » Logged
Bad bug
« Reply #15 on: May 09, 2016, 09:12:55 am »
Can see that he is using a dry sump oiling system on the engine. Would love to see more of this engine.
« Reply #16 on: May 09, 2016, 09:17:03 am »
SCC is 3 months away Wink
Elnef
« Reply #17 on: May 09, 2016, 09:44:50 am »
Pauter crank og custom made ?
« Reply #18 on: May 09, 2016, 10:48:11 am »
Pauter crank and Pauter rods. His own alu pushrods and his own cam grind. Precision turbo. E85.
Best rgs
BB
Bad bug
« Reply #19 on: June 05, 2016, 21:41:45 pm »
Does anyone know who's dry sump pump skinne is using.
« Last Edit: June 05, 2016, 21:45:46 pm by Bad bug » Logged
