October 16, 2026, 22:20:07 pm
| |-+  For sale!
| | |-+  Engine and transmission for sale, best of the best.
Author Topic: Engine and transmission for sale, best of the best.  (Read 2984 times)
JS
« on: May 05, 2016, 16:44:33 pm »
Update: Box is SOLD.
Engine still for sale, 100.000SEK / 10.800€
My friend Tony in Sweden is selling some pretty awesome stuff.
Contact Tony on tonysandmark@yahoo.se
ENGINE - 2388 cc Type 1 - 302,5 HP at 8400, torque 294 Nm at 6600:
Case: AutoLinea
Crankshaft: SCAT flanged billet 86 mm T4 all mains
Flywheel and clutch: SCAT with RLR black magic ,stage 1
Rods: SCAT 5,7” H-beam
Rod bolts: Carrillo SPS, 12 point head
Cylinders: JPM
Pistons: 94 mm JE ultra low JPM
Camshaft & Gears: JPM Raptor custom grind 17,35 mm lift, flat tappet, Magnum gears
Lifters: JAYCEE tool steel
Cylinder head studs: Raceware Hi tensile 8 mm
Heads: JPM MS 250, CR 15,4:1
Rockers: JPM 5 point
Valves & Springs: Manley Titanium 48x38 mm, Oteva springs
Retainers: Titanium
Pushrods & Tubes: Manton double tapered, JPM tubes
Carbs: Gene Berg 58’s on welded angle flow manifolds, 50 mm venturi, Teflon coated by Tommy Tc Costello , CSP linkage
Oiling: CB 4 Gear dry sump, special case modifications, JayCee bypass
Distributor: MSD
JPM alternator
Exhaust: CSP Wasp 3
Ignition box: MSD 6
Blaster 2 Coil
« Last Edit: May 08, 2016, 19:38:48 pm by JS » Logged
Signature.
JS
« Reply #1 on: May 08, 2016, 19:36:13 pm »
Signature.
