October 13, 2026, 04:07:02 am
| | |-+  welding a magnesium case
Author Topic: welding a magnesium case  (Read 5346 times)
kever65
« on: May 21, 2016, 20:43:48 pm »
Hello,
is it OK to bore a as 41 case to 94without welding behind the NR 3 cylinder, this is for a mild motor for the convertible, stock heads, 110 cam, 40 idf. What is your experience?
thanks
dragvw2180
« Reply #1 on: May 22, 2016, 00:10:20 am »
If the case is only bored enough for the cylinder to seat into the case properly then I believe you will be fine. I have had cases that were clearanced for 82 stroke and 94 bore that were not welded up, never had a problem cracking back there. Mike McCarthy
« Reply #2 on: May 22, 2016, 11:22:49 am »
it works just as it is with what you have planned
kever65
« Reply #3 on: May 22, 2016, 14:07:15 pm »
OK,
Thanks for the info.
Kind regards Davy
