September 22, 2026, 21:24:02 pm
| |-+  For sale!
| | |-+  1963 Turbo Waterboxer Bug 400+hp
Author Topic: 1963 Turbo Waterboxer Bug 400+hp  (Read 7457 times)
m.m.p
« on: May 22, 2016, 01:41:23 am »
Its finally time to put up for sale my beloved Grey 1963 Turbo Bug, One of the first three Outlaw Flat Four cars, I really don't want to do this as I've own it for over 20 years now but as ive now moved abroad and can no longer use or time to complete my bug its now up for sale. The car needs finishing but 90% of the parts are included, It has had numerous engine and gearbox incarnations over the years but now has a built 1.9 turbo waterboxer mated to a UN1 5 speed gearbox, the body is all steel and in very good condition with no rust and custom beautful Grey paint, it has a full Cert CDS cage and is back halved with coil-overs and irs suspension. It was the one of fastest bug on the street with over 400hp and would run consist 10.8s in the 1/4 and with tarmac rally tires on the street nothing could touch it.
Engine specs
1.9 Waterboxer
40x35 heads port and polished
H-beam rods 3/8 bolt with 24mm small end
8-1 comp
Scat duel springs
1.3 rockers
Fk87 cam
Scat lifters
Case bushed for T1 lifters
200mm forged flywheel
Stage 2 kennedy
Black magic disc
1000cc injectors
Hx35 turbo
Stainless header
Water to air charger cooler
V3 Megasquirt ECU
Cosworth throttle body
Spec'ed for 500hp
Gearbox
UN1 Renault 21turbo
Flipped 3.44 R&P
T2 bellhousing
T2 to un1 adaptor plate
Modified Scat dragfast shifter for 5speed
944 axels
T1 input shaft
Suspension
Front 4in narrowed linkpin beam with adjusters
2in dropped spindles
Stock shocks
Porsche 996 vented discs
Porsche 996 4pot calipers
Rear 944 irs arms and spring plates
Boxster vented discs
944 calipers and hand brake assembly
AVO adjustable shocks with 600lb springs
No frame forks
Suspension and drivetrain mounted form above direct to cage
Wheels are 928 rare 6in wide front and rear
Late duel master cylinder
Interior
2 bucket seats and 5 point harnesses
Black carpet
Full standard dash
150mph Porsche Speedo
AutoMeter 5inch tach ,shift light
Grey roof lining
One piece electric windows
Custom pop-out rear quarters
Cal-Look rubbers
Its priced to sell fast as all the parts separately would be over £15k,
Im only asking £6k because I cant bear to see it sit parked up for the next 20 years, someone should enjoy it like i did, time to move on.
Marco Mansi
The car needs a good amount of work to be completed and has to be towed, dose NOT run and it is a project car. Needs numerous small parts for it to be compleat, its in the Manchester area.
 If anyone is interested or wants more info please email me at marcomansi@aol.com
Ok a list to finish of the car and get it running
Megasquirt Ecu needs wiring up(included)
Engine bay needs wiring
Fuel pump and fuel tank need sorting out(included)
Need to finish off stainless header and mount wastegate(included)
Mount chargecooler and silicone hoses(included)
Fit dump-valve(included)
The gearbox is missing one output flange but other than that is ready to go.
Bleed brakes
Finish of rear fire wall/paneling
Install rear window and front window lower scrapers(included)
Fit carpet set(included)
Bolt seats back in(included)
Needs engine oil and gearbox oil
Clean and polish the car!
« Last Edit: May 22, 2016, 14:33:47 pm by m.m.p » Logged
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
max Der Bahnstormerz
« Reply #1 on: May 22, 2016, 04:10:18 am »
There are some things you shouldn't sell!!
m.m.p
« Reply #2 on: May 22, 2016, 11:52:55 am »
Your 100% right Max 😞
Marco Mansi
0044(0)7947 660 924
« Reply #3 on: May 22, 2016, 19:47:46 pm »
Ship it out to the states and have some fun with it!
Greasy Dave
« Reply #4 on: May 26, 2016, 18:22:03 pm »
What an absolute bargain priced project,vehicle that is.
m.m.p
« Reply #5 on: May 26, 2016, 22:45:19 pm »
Sale pending
Marco Mansi
0044(0)7947 660 924
« Reply #6 on: May 27, 2016, 02:54:50 am »
Sale pending
Don't do it!
Paul Bahnstormerz
« Reply #7 on: June 01, 2016, 20:13:07 pm »
Max is right, not often, but this time he's right! He was right when he told me not to sell mine!
Hope you're well! But to second Max, don't do it!!!!
m.m.p
« Reply #8 on: June 01, 2016, 23:02:24 pm »
Sold
Marco Mansi
0044(0)7947 660 924
« Reply #9 on: June 02, 2016, 18:18:22 pm »
Sold
Muppet!
