July 23, 2026, 03:55:37 am
Autocraft 2-stage Dry Sump Oil Pump, CB Tank, Canton Filter
Topic: Autocraft 2-stage Dry Sump Oil Pump, CB Tank, Canton Filter (Read 2823 times)
Stripped66
May 28, 2016, 20:44:18 pm »
Autocraft 2-stage dry sump oil pump with fuel-pump drive (no fittings included); CB Performance dry sump oil tank, modified for -12 oil return and oil feed fittings, and -10 breather fitting (fittings included, as pictured; tank mounts also included, not pictured); and, Canton-Mecca 6" canister oil filter (not pictured;body is tapped for 1/8 npt oil pressure sender).
$500, plus shipping (from SC, USA).
Will consider trades for Autocraft 1 Stage, 1.5 Stage or Pauter 1 stage oil pump.
Last Edit: May 28, 2016, 23:06:05 pm by Stripped66
Stripped66
Re: Autocraft 2-stage Dry Sump Oil Pump, CB Tank, Canton Filter
June 04, 2016, 16:45:31 pm »
Sold.
