September 23, 2026, 22:30:03 pm
Waterman Fuel Pump and Cable-Drive Components
Topic: Waterman Fuel Pump and Cable-Drive Components (Read 3303 times)
Stripped66
May 28, 2016, 20:53:03 pm »
Waterman mechanical fuel pump, cable-drive bulkhead and fuel tank cover, and gilmer-belt pulley drive. The fuel pump can also be mounted to the frontside of the gilmer-belt pulley drive, or mounted to an Autocraft or Pauter drysump oil pump (if it has a fuel-pump drive) using the collar that is pictured. No cable is provided (order direct from Waterman once you determine how long of a cable you need). Great from a high-output EFI or MFI set-up.
$600, plus shipping. Will consider trades for Autocraft 1 Stage, 1.5 Stage or Pauter 1 stage oil pump.
Last Edit: May 28, 2016, 23:05:23 pm by Stripped66
