September 23, 2026, 02:09:43 am
Longer injector hats
Topic: Longer injector hats (Read 5103 times)
Erlend / bug66
Global Moderator
SCC Event
June 07, 2016, 21:37:46 pm »
Had a MAJOR fuel spill yesterday. Dropped at least 2 gallons on the highway..
I've got older VW Speedshop 45mm throttle bodies, and ID1000s injectors with 11mm top hat extenders. THey are not nearly long enough. Need 5-8mm longer top hats.
I've tried to search, but came up empty handed.
The ones I have are 11mm above the "ridge".
See picture.
Last Edit: June 07, 2016, 21:43:29 pm by Erlend / bug66
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Chip
Re: Longer injector hats
June 08, 2016, 02:18:18 am »
Spooky! I pulled my hats off of my IDs. Just one more point to leak. What kind of injectors are those manifolds supposed to be used with. Purple top IDs should be pretty standard length.
Erlend / bug66
Global Moderator
SCC Event
June 08, 2016, 19:43:19 pm »
Ordered a set of height adapters for 1/2 size injectors. Will need to shim the fuel rail upwards, but thats perfectly fine.
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
June 17, 2016, 08:47:55 am »
Alot better now.
Shimmed the rail up 10.5mm
Now there is 1.5mm play in height under the rails.
The '67:
The '59:
Not yet..
