September 23, 2026, 11:37:43 am
| | |-+  Useful on-line tyre size calculator
Author Topic: Useful on-line tyre size calculator  (Read 5195 times)
« on: September 28, 2007, 09:37:48 am »
Just discovered this useful on-line resource that allows you to calculate tyre diameter etc – it even goes down as skinny as 135 x 15...
http://www.tyresave.co.uk/tyresize.html
« Reply #1 on: September 28, 2007, 17:57:47 pm »
You can also figure out tire diameter with some simple math... Say you have a 205/70/15 and you need to know the diameter in inches. First take 205 and divide by 25.4 to convert millimeters to inches = 8.07". Next, multiply that by the aspect ratio, in this case it is 70%, or .7 = 5.65". That will give you the height of one sidewall. Now since 2 sidewalls make up the diameter of a tire, multiply that by 2 = 11.3". Add in the diameter of your wheel, 15", and you have 26.3", the mathematical diameter of a 205/70/15.
« Reply #2 on: September 28, 2007, 19:05:51 pm »
Zach, I know... but how much quicker is it to select three numbers and hit a 'button'! Grin
