September 21, 2026, 19:01:16 pm
Technical stuff
Transmissions...
Topic: Transmissions... (Read 21451 times)
andrewlandon67
Transmissions...
June 16, 2016, 04:19:43 am »
Well, there's less than a month to go until the big VW show of the year here in Denver, and I somehow managed to blow up my stock differential... again. Any advice on what sort of tranny I could throw together in that amount of time? Keep in mind, I'm only working with 110-120 hp, so I don't need some 5 rib bus monstrosity, and I already have a Super-Diff and h.d. side plate. Thanks for any help!
14.877 @ 88.85 mph
He who waves at 911 drivers
Re: Transmissions...
June 16, 2016, 16:30:24 pm »
A stock built trans should handle that power without problems. Are you preloading?
kever65
June 20, 2016, 20:20:42 pm »
I took my all steel bug in to the 12s with the same parts, preloading your tranny is the key.
grtz
andrewlandon67
June 27, 2016, 06:46:43 am »
No, I'm not preloading it, I guess I haven't figured out that part of drag racing just yet
14.877 @ 88.85 mph
June 27, 2016, 07:21:54 am »
Quote from: andrewlandon67 on June 27, 2016, 06:46:43 am
Here is a test;
Make sure your car is in 1`st gear with no handbrake. Go out of the car and wriggle it back and forth. You will probably find out that it moves 2-3 inches. This is the slack you want to remove when you dragrace and that is why it is important to pre-load the gearbox and also your car.
-BB-
andrewlandon67
June 28, 2016, 08:50:49 am »
Quote from: BeetleBug on June 27, 2016, 07:21:54 am
Here is a test;
-BB-
Ah, that makes sense... Now here's the real amateur question; how the hell do I preload it?
14.877 @ 88.85 mph
June 28, 2016, 09:15:22 am »
Line lock or handbrake.
Light the first 2 light, activate line lock or pull some handbrake, creep up to the next lights (rear of car will get pulled down some).
You feel when it's preloaded.
Last Edit: June 28, 2016, 09:17:02 am by Erlend / bug66
RichardinNZ
Re:
June 28, 2016, 09:15:52 am »
I'm glad someone has asked this....(even though I am sure it is not an issue with my 36+hp)...
Sent from my SM-N920I using Tapatalk
'58 Bug; NZ assembled
Dual Carb 36hp
henk
Re:
June 28, 2016, 09:57:42 am »
Quote from: RichardinNZ on June 28, 2016, 09:15:52 am
I have seen people blow there gearbox with a mild 1641 twice in a year
And others drive for years with a stock gearbox and a 150bhp engine and have np problemes.
So i'm pretty sure there are people out there who can brake there box xith 36bhp as well.
Think it is all about your driving style.
Henk!!!
andrewlandon67
June 29, 2016, 06:27:00 am »
Awesome, thanks for the advice! Now I just need to get it up to the shop to un-blow it up and get a little practice in!
As an aside, shoutout to the admins for getting the technical board up and running! I just read a bit about it last night, it's an honor to have my post be one of the first in here, even if it's about something as simple as how to not blow up a transmission
14.877 @ 88.85 mph
Berger
www.bugrent.no
June 29, 2016, 09:03:39 am »
A simple modification to make a stage brake, drill a hole through the parking brake handle when the lock button is pressed in, then put a locking pin in the hole. Use the parking brake when stageing, releas at green light, then your tranny will be preloaded
This is my simple religion:
-Be cool
-Don't be an asshole
June 29, 2016, 09:23:38 am »
Quote from: Berger on June 29, 2016, 09:03:39 am
Same as that on 67 & Old cab, simple and just pull pin out again to return it to normal use for road etc
June 30, 2016, 20:33:34 pm »
i did about the same thing, but i opted to drill the hole further down the bracket. that way, when the pin is in you lock out the thoothed part that locks the handbrake (the part that pivots). that way you don't have anything around your hand when you use the lever as a staging brake.
