September 24, 2026, 21:40:12 pm
Dpr 84mm crank,Short IDA manifolds, alt mounts, carillo rods
Topic: Dpr 84mm crank,Short IDA manifolds, alt mounts, carillo rods (Read 24091 times)
June 17, 2016, 08:14:24 am »
Set of 5.8 carrillo rods, chevy journal, 5/16th bolts, I have used these to mock up only, never ran so as near to new as you can get
£800[cost £1300 new now]
Last Edit: July 22, 2017, 14:42:36 pm by richie
Re: 5.8 carrillo rods, used FK89 with lifters and straight cuts
June 21, 2016, 15:23:43 pm »
Used Engle FK89 cam, checks out good with matched lifters, marked so they go back in correct place,
Sold
Last Edit: February 01, 2017, 20:49:21 pm by richie
Re: 5.8 carrillo rods, used FK89 &lifters & straight cuts, 3x 94mm long cylinders
July 01, 2016, 13:27:46 pm »
Also have 3 x new 94mm cut to length long cylinders, will sell as singles or together
Two sold one left
Last Edit: April 09, 2017, 13:40:30 pm by richie
Re: carrillo rods, used FK89lifters/straight cuts, 3x94mm long cyl,28mm torsion bar
July 05, 2016, 12:27:48 pm »
New 28mm Sway a way H/D torsion bars, 21 3/4 long so short version, new in box
Sold
Last Edit: August 31, 2016, 08:28:29 am by richie
Re: carrillo rods, used FK89lifters/straight cuts,94mm cyl,more added
July 19, 2016, 14:23:04 pm »
DPR 84mm crank,t4 center main, chey rod journals, wedgemated with 12lb VW flywheel, un used £800
pictures added
Last Edit: December 09, 2016, 17:06:39 pm by richie
Re: Performance part,used FK89lifters/straight cuts,94mm cyl,dpr crank,more added
July 23, 2016, 11:25:52 am »
Jaycee fuel pump block off £15
Waterboxer stainless pushrod tubes,[ wide mouth at one end] £60
Last Edit: December 09, 2016, 17:06:58 pm by richie
July 23, 2016, 12:40:29 pm »
Hi Richie,
Crank is calling my name! My case has standard type 1 centre main, is a conversion bearing an acceptable way of running this crank, is thy something you would recommend or not?
Lee
July 23, 2016, 13:43:57 pm »
Yes that is how I did it in 67 engine
July 23, 2016, 16:43:22 pm »
Great. Just need to sell my tony Mance and DMS wedgemated cranks then I will buy yours
July 25, 2016, 14:15:08 pm »
More
1 inch trans raise gearbox mount
Sold
DLX-FE race alternator mount £70
Reichspeed alternator mount £75 [ does not inc alternator but that is for sale as well]
DLX-FE trailer tie downs[ front and rear to attach trailer straps to car] £ 80 for all 4
Last Edit: September 01, 2016, 09:50:55 am by richie
Re: Performance part,94mmcyl,dpr crank,Short IDA manifolds, alt mounts,more added
July 25, 2016, 20:08:07 pm »
Last Edit: December 09, 2016, 17:07:39 pm by richie
Jay Aldred
August 05, 2016, 06:43:12 am »
Ritchie is the Jaycee filter still available?. Cheers Jay.
August 05, 2016, 18:33:39 pm »
Last Edit: July 22, 2017, 14:43:30 pm by richie
August 28, 2016, 17:41:52 pm »
New 1 3/4 ceramic coated merged header
£240
heo2man
August 30, 2016, 12:06:30 pm »
PM'd you
August 30, 2016, 20:03:56 pm »
Torsion bars and 1inch trans raise mount sold
Last Edit: September 01, 2016, 09:51:29 am by richie
September 15, 2016, 09:05:20 am »
Pair new M&H 215/65/15 drag radial. £430
Last Edit: January 30, 2017, 10:04:06 am by richie
Type3s
September 15, 2016, 12:28:59 pm »
Hi,
is this Set still available?
Would you send it to Germany?
Set of Heads up spring loaded push rod tubes, they are quite long, were used on 86mm stroke/6inch rod engine £50
Thank you Daniel
September 15, 2016, 12:36:30 pm »
Quote from: Type3s on September 15, 2016, 12:28:59 pm
Hi,
Thank you Daniel
Yes it is, and yes I would, I will check postage cost and let you know
September 15, 2016, 17:23:25 pm »
Hi,
Thank you Daniel
PM sent
notchdrag
September 25, 2016, 17:09:20 pm »
HI Ritchie,
The DPR 84mm crank,t4 center main, chey rod journals, wedgemated with 12lb VW flywheel, are they always to sell?
Thanks yours answers.
Tony's
www.notchdrag.blogspot.com
September 25, 2016, 18:57:20 pm »
Quote from: notchdrag on September 25, 2016, 17:09:20 pm
HI Ritchie,
Tony's www.notchdrag.blogspot.com
Yes I still have them for sale
November 02, 2016, 17:33:35 pm »
Add updated
November 13, 2016, 20:34:21 pm »
New CB aluminium raised deck & roof case, 94 bore, stroker clearance etc, also converted for 6 head stud per cylinder, bronze thrust conversion for flange crank, cut for flange seal, set up for type 4 to type 1 bearings and also roller lifters, case is new and comes with roller lifters, Turbo roller cam also available.
Case £1500 [bare case is nearly £1000 now] so this is cheap
Pics shortly
December 09, 2016, 17:08:40 pm »
Lots for sale still including the wedgemate crank & flywheel
Re: CSP 10cm oversize rear wings ,dpr crank,Short IDA manifolds, alt mounts
December 22, 2016, 10:10:41 am »
Pair of CSP fiberglass 10cm oversize rear wings, new have had some material added at bottom front edge to allow mounting them higher on body for raised torsion etc, but this could easily be removed if not needed, cost £330
asking £200
Wings sold
Last Edit: April 09, 2017, 13:42:14 pm by richie
January 30, 2017, 10:04:55 am »
Alternator sold
February 01, 2017, 20:49:40 pm »
Cam sold
pWolf
February 01, 2017, 23:43:37 pm »
Quote from: richie on February 01, 2017, 20:49:40 pm
Cam sold
And you don't waste any time either, already got shipping confirmation
Thanks lot !
pWolf- Part of the Airwolfs crew!
https://m.facebook.com/AirWolfs-153115064754266/?ref=bookmarks
Re: Dpr 84mm crank,Short IDA manifolds, alt mounts, carillo rods
Reply #29 on:
April 09, 2017, 13:43:03 pm »
CSP wings, and 2 94mm cylinder sold
Still one new 94mm long cut to length cylinder available
