October 13, 2026, 18:43:42 pm
| |-+  For sale!
| | |-+  Dpr 84mm crank,Short IDA manifolds, alt mounts, carillo rods
Author Topic: Dpr 84mm crank,Short IDA manifolds, alt mounts, carillo rods  (Read 24403 times)
« on: June 17, 2016, 08:14:24 am »
Set of 5.8 carrillo rods, chevy journal, 5/16th bolts, I have used these to mock up only, never ran so as near to new as you can get Smiley
£800[cost £1300 new now]
« Last Edit: July 22, 2017, 14:42:36 pm by richie » Logged
« Reply #1 on: June 21, 2016, 15:23:43 pm »
Used Engle FK89 cam, checks out good with matched lifters, marked so they go back in correct place,
Sold
« Last Edit: February 01, 2017, 20:49:21 pm by richie » Logged
« Reply #2 on: July 01, 2016, 13:27:46 pm »
Also have 3 x new 94mm cut to length long cylinders, will sell as singles or together
Two sold one left
« Last Edit: April 09, 2017, 13:40:30 pm by richie » Logged
« Reply #3 on: July 05, 2016, 12:27:48 pm »
New 28mm Sway a way H/D torsion bars, 21 3/4 long so short version, new in box  Sold
« Last Edit: August 31, 2016, 08:28:29 am by richie » Logged
« Reply #4 on: July 19, 2016, 14:23:04 pm »
DPR 84mm crank,t4 center main, chey rod journals, wedgemated with 12lb VW flywheel, un used £800
pictures added Smiley
« Last Edit: December 09, 2016, 17:06:39 pm by richie » Logged
« Reply #5 on: July 23, 2016, 11:25:52 am »
Jaycee fuel pump block off £15
Waterboxer stainless pushrod tubes,[ wide mouth at one end] £60
« Last Edit: December 09, 2016, 17:06:58 pm by richie » Logged
« Reply #6 on: July 23, 2016, 12:40:29 pm »
Hi Richie,
Crank is calling my name! My case has standard type 1 centre main, is a conversion bearing an acceptable way of running this crank, is thy something you would recommend or not?
« Reply #7 on: July 23, 2016, 13:43:57 pm »
Yes that is how I did it in 67 engine
« Reply #8 on: July 23, 2016, 16:43:22 pm »
Great. Just need to sell my tony Mance and DMS wedgemated cranks then I will buy yours Smiley
« Reply #9 on: July 25, 2016, 14:15:08 pm »
More Smiley
 1 inch trans raise gearbox mount    Sold
DLX-FE race alternator mount £70
Reichspeed alternator mount £75 [ does not inc alternator but that is for sale as well]
DLX-FE trailer tie downs[ front and rear to attach trailer straps to car]  £ 80 for all 4
« Last Edit: September 01, 2016, 09:50:55 am by richie » Logged
« Reply #10 on: July 25, 2016, 20:08:07 pm »
« Last Edit: December 09, 2016, 17:07:39 pm by richie » Logged
Jay Aldred
« Reply #11 on: August 05, 2016, 06:43:12 am »
Ritchie is the Jaycee filter still available?. Cheers Jay.
« Reply #12 on: August 05, 2016, 18:33:39 pm »
« Last Edit: July 22, 2017, 14:43:30 pm by richie » Logged
« Reply #13 on: August 28, 2016, 17:41:52 pm »
New 1 3/4 ceramic coated merged header
£240
heo2man
« Reply #14 on: August 30, 2016, 12:06:30 pm »
PM'd you
« Reply #15 on: August 30, 2016, 20:03:56 pm »
Torsion bars and 1inch trans raise mount sold Smiley
« Last Edit: September 01, 2016, 09:51:29 am by richie » Logged
« Reply #16 on: September 15, 2016, 09:05:20 am »
Pair new M&H 215/65/15 drag radial.  £430
« Last Edit: January 30, 2017, 10:04:06 am by richie » Logged
Type3s
« Reply #17 on: September 15, 2016, 12:28:59 pm »
Hi,
is this Set still available?
Would you send it to Germany?
Set of Heads up spring loaded push rod tubes, they are quite long, were used on 86mm stroke/6inch rod engine  £50
Thank you Daniel
« Reply #18 on: September 15, 2016, 12:36:30 pm »
Hi,
Thank you Daniel
Yes it is, and yes I would, I will check postage cost and let you know  Smiley
« Reply #19 on: September 15, 2016, 17:23:25 pm »
Hi,
Thank you Daniel
PM sent Smiley
notchdrag
« Reply #20 on: September 25, 2016, 17:09:20 pm »
HI Ritchie,
The DPR 84mm crank,t4 center main, chey rod journals, wedgemated with 12lb VW flywheel, are they always to sell?
Thanks yours answers.
Tony's   www.notchdrag.blogspot.com
« Reply #21 on: September 25, 2016, 18:57:20 pm »
HI Ritchie,
Yes I still have them for sale Smiley
« Reply #22 on: November 02, 2016, 17:33:35 pm »
Add updated Smiley
« Reply #23 on: November 13, 2016, 20:34:21 pm »
New CB aluminium raised deck & roof case, 94 bore, stroker clearance etc, also converted for 6 head stud per cylinder, bronze thrust conversion for flange crank, cut for flange seal, set up for type 4 to type 1 bearings and also roller lifters, case is new and comes with roller lifters, Turbo roller cam also available.
Case £1500 [bare case is nearly £1000 now] so this is cheap
Pics shortly
« Reply #24 on: December 09, 2016, 17:08:40 pm »
Lots for sale still including the wedgemate crank & flywheel  Smiley
« Reply #25 on: December 22, 2016, 10:10:41 am »
Pair of CSP fiberglass 10cm oversize rear wings, new have had some material added at bottom front edge to allow mounting them higher on body for raised torsion etc, but this could easily be removed if not needed, cost £330
asking £200
Wings sold
« Last Edit: April 09, 2017, 13:42:14 pm by richie » Logged
« Reply #26 on: January 30, 2017, 10:04:55 am »
Alternator sold Smiley
« Reply #27 on: February 01, 2017, 20:49:40 pm »
Cam sold Smiley
pWolf
« Reply #28 on: February 01, 2017, 23:43:37 pm »
Cam sold Smiley
And you don't waste any time either, already got shipping confirmation Smiley Thanks lot ! Smiley
« Reply #29 on: April 09, 2017, 13:43:03 pm »
CSP wings, and 2 94mm cylinder sold
Still one new 94mm long cut to length cylinder available
