September 21, 2026, 17:53:52 pm
| | |-+  vw bus 228mm flywheel resurfacing depth
Author Topic: vw bus 228mm flywheel resurfacing depth  (Read 11303 times)
tezer
« on: June 27, 2016, 13:33:20 pm »
Hi need some help whit this!
my flywheel is 25 mm in measurement A as shown in drawing
but that says 22,5mm but perhaps 228mm flywheels are diffrent ?
tezer
« Reply #1 on: June 28, 2016, 09:32:57 am »
nobody has this measurements ?
tezer
« Reply #2 on: June 30, 2016, 21:22:10 pm »
i find out my self! 228mm type 4 flywheel is 25mm
« Reply #3 on: July 06, 2016, 06:39:40 am »
They are all the same . Important is that you must look for the clutch which works best with 3-3,5 mm pressure. that is when you lay it with disc on the flywheel
tezer
« Reply #4 on: July 06, 2016, 09:24:18 am »
thank you udo!
do you have a clutch brand that you know works good ?
