June 09, 2026, 16:14:59 pm
Latest Member: mvptkfjb
| |-+  Technical stuff
| | |-+  Narrowed irs trailing arms. Who does them?
Pages: 1 [2] Print
Author Topic: Narrowed irs trailing arms. Who does them?  (Read 30465 times)
« Reply #30 on: October 12, 2018, 18:48:56 pm »
Here's some I am just finishing up that are 20mm narrowed and I tweaked the camber on them so that they are at zero still when stationary even though car is lowered a little Wink
« Reply #31 on: October 12, 2018, 19:03:22 pm »
More pics as it will only let me add 2 to each post Roll Eyes
« Reply #32 on: October 12, 2018, 19:04:25 pm »
 Smiley
jmarkha1
« Reply #33 on: October 12, 2018, 20:54:49 pm »
NICE WORK - Realistically how narrow could you go using that technique and retain stock type 3 drums? - 25-30MM?
« Reply #34 on: October 13, 2018, 00:49:46 am »
With custom axles yes looks like 30mm might be possible but until they are cut up its hard to say for sure
« Reply #35 on: October 14, 2018, 03:12:22 am »
That's how I did mine many years ago.  Mine are narrowed 34mm each side.
Beware, your inner ball bearing will not fit.  That's because of the weld on the OD of the bearing housing being right at the bearing. Ideally, you would put the TA on your mill and bore it back to the stock diameter.
Have you checked the clearance between your tire and the tab that bolts to the spring plate?
« Reply #36 on: October 14, 2018, 17:21:34 pm »
Bearings fit and yes checked clearance, got plenty Smiley
Pages: 1 [2] Print
