November 03, 2026, 16:49:50 pm
| |-+  Wanted
| | |-+  48 Ida pump jet
Author Topic: 48 Ida pump jet  (Read 4959 times)
Rocket Ron
It's old school for a reason
« on: June 28, 2016, 20:02:23 pm »
50 pump jet required for early 48 Ida
As per photo
« Last Edit: June 30, 2016, 11:08:04 am by Ron Elliot » Logged
13.12 @ 101.84
Grooving out on life
Rocket Ron
« Reply #1 on: June 30, 2016, 11:15:17 am »
Also looking for studs for round the top that hold the base to the top plate and acorn nuts
13.12 @ 101.84
WhiteTrash
« Reply #2 on: June 30, 2016, 20:09:04 pm »
Eurocarb do every part you need mate.
https://www.dellorto.co.uk/product-category/weber-carburettors-parts/carburettor-parts-weber-carburettors-parts/ida-dual-barrel-parts/
I've used them for years now and all the jets etc I ever had came from them. The Weber pump jets are all the same, whether old Italian or newer Spanish IDA.
HOFF#67
« Reply #3 on: June 30, 2016, 20:29:38 pm »
As per photo
Ron, early IDAs have a screw in squirter/pump jet on all the ones I have had, I think that is a later IDA with a push in version? I have some studs and nuts if you don't get any joy from where frank suggested
Rocket Ron
« Reply #4 on: June 30, 2016, 22:03:17 pm »
Cheers frank, I had already called and chat with them this morning. I've ordered some studs. They have some of the size I needed and are ordering the rest direct from weber. Very willing to help.
As per photo
Hi Richie
I know the type you are talking about, the little brass ones. There appears to be two types of later pump jet, (the ones as pictured above )with the little turn down and ones without the slight turn down on the end ( as pictured below ) Euro carb had this as well as all good. But thanks for the offer
Regards Ron
« Last Edit: June 30, 2016, 22:05:54 pm by Ron Elliot » Logged
13.12 @ 101.84
WhiteTrash
« Reply #5 on: July 01, 2016, 19:40:40 pm »
As per photo
Yes sorry, you're right they also do brass pump jets, fixed with a hollow union bolt. Just trying to remember what other carbs they did them on.
HOFF#67
