September 21, 2026, 17:54:53 pm
Technical stuff
Hydraulic clutch setup
Topic: Hydraulic clutch setup (Read 42462 times)
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 11:11:04 am »
I've seen this a few times lately, and can't really understand why it's like this.
Why would 2 seemingly equal hydraulic clutch setups have different pedal feel?
I've got:
Stage 4, thick Black Magic. 5/8" master and 7/8" slave cylinder. AN3 lines, line lock and restrictor valve for clutch management.
Pedal is fairly heavy (became better after driving it some)
Other have the same-ish setup, but pedal is so much lighter.
I don't mind a longer throw on the pedal, if that gives me a softer pedal.
Smaller master or bigger slave? AN3 or AN4?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Re: Hydraulic clutch setup
June 29, 2016, 11:27:34 am »
I was thinking this would make a good tech topic and maybe even a sticky if enough info is added with CM included
Length of clutch arm on gearbox makes huge difference, I have been making longer arms for mendys & bus boxes myself. Its not always possible to fit longest arm on stock bodied car as it interferes with boot floor area
I use 1 3/4 master cylinder and cnc 7/8 slave cylinder, steel 4.75mm[ 3/16th? ] front to back, then -3 flexi from chassis/pan to slave, I hated way 1 5/8 master felt when I tried it.
Also I am sure people are using different valves for CM, and the push through flow will be different on them so add to different feel as well
Finally have you shimmed clutch cover at all? that makes difference to how it acts and feels as well
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 11:51:33 am »
I tried the stock length Type 1 arm, but needed to shorten it, to get enough throw, to release the clutch.
Shortened about 1/2".
The '67:
The '59:
Not yet..
Berger
www.bugrent.no
June 29, 2016, 11:55:32 am »
A T25 has a hydraulic clutch that feels very "normal". Would be nice to know the exact spec on parts from those if anyone have?
This is my simple religion:
-Be cool
-Don't be an asshole
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 11:59:52 am »
Quote from: Berger on June 29, 2016, 11:55:32 am
Sure does not have a Stage 4..
The '67:
The '59:
Not yet..
Berger
www.bugrent.no
June 29, 2016, 12:10:36 pm »
Quote from: Erlend / bug66 on June 29, 2016, 11:59:52 am
No, but was thinking more about travle, flow and ratio. My guess is it would handle stage 4 pretty well
-Be cool
dragvw2180
June 29, 2016, 14:08:51 pm »
My setup is almost exactly the same as Richie has with the exception of my lines, I use AN- 4 PTFE lines all the way through . I do have a line lock installed in between for my delay box . Mike McCarthy
June 29, 2016, 14:33:34 pm »
Quote from: Erlend / bug66 on June 29, 2016, 11:51:33 am
That's your problem then, no wonder its heavy, I am using 100mm arms. So did you not have enough travel at slave? was it maxed out? or was there not enough travel at pedal to move slave fully? Guessing you are using the in the tunnel kit? I don't know anything about ratios on those
pWolf
June 29, 2016, 15:12:07 pm »
Doesn't Kalle (beetlebug) have a nice setup ?
pWolf- Part of the Airwolfs crew!
https://m.facebook.com/AirWolfs-153115064754266/?ref=bookmarks
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 15:45:38 pm »
Quote from: richie on June 29, 2016, 14:33:34 pm
Yes, I understand that shortening the arm will make my left foot stronger
I tried a 75mm arm, but when the master was fully depressed, if did not pull the slave and arm enough. The point of clutch release was with the pedal almost all the way back.
CNC kit with 5/8" master and 7/8" slave. Master with a straight link behind the pedal.
Last Edit: June 29, 2016, 15:48:46 pm by Erlend / bug66
The '67:
The '59:
Not yet..
June 29, 2016, 15:50:12 pm »
Quote from: Erlend / bug66 on June 29, 2016, 15:45:38 pm
there's your problem --- Master should be in the range of twice the size of the slave to make the system behave nicely
Last Edit: June 29, 2016, 15:53:23 pm by Fiatdude
http://selvedgeyard.com/
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 15:55:07 pm »
Quote from: Fiatdude on June 29, 2016, 15:50:12 pm
Ok? Every thread I've read states that if the slave/arm has enough travel; the smallest MC to SC will give the lightest pedal, but needs to travel further?
The '67:
The '59:
Not yet..
June 29, 2016, 16:27:41 pm »
So maybe slave can move more? and a bigger master would move more fluid for same pedal travel and move slave more[ I think]
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 20:25:01 pm »
Quote from: richie on June 29, 2016, 16:27:41 pm
I don't think it will have a a softer pedal then? Just move the arm more?
The '67:
The '59:
Not yet..
June 29, 2016, 20:51:30 pm »
Quote from: Erlend / bug66 on June 29, 2016, 20:25:01 pm
But then you can use longer arm
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 20:55:25 pm »
Quote from: richie on June 29, 2016, 20:51:30 pm
That's true
The '67:
The '59:
Not yet..
June 29, 2016, 20:56:50 pm »
The other thing that occurred to me is, why the hell you are using a stage 4 and black magic, I expect to see 8s at least with that much clutch
stussyrich
June 29, 2016, 21:00:17 pm »
is there enough throw on that pedal. does it activate the master fully.
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 21:02:02 pm »
Quote from: richie on June 29, 2016, 20:56:50 pm
Better to have too much clutch, and manage the clutch slip, than having too little
8s will never happen. If I break into sub 10.5s I'll be really happy
And then chase a 9.99
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 21:02:35 pm »
Quote from: stussyrich on June 29, 2016, 21:00:17 pm
Yes, the MC bottoms out before the pedal
The '67:
The '59:
Not yet..
stussyrich
June 29, 2016, 21:05:30 pm »
ok cool just looked like it wouldn't, maybe just the pic.
Quote from: Erlend / bug66 on June 29, 2016, 21:02:35 pm
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 21:11:48 pm »
Quote from: stussyrich on June 29, 2016, 21:05:30 pm
I shortened the MC pushrod, but it's bottoming nicely before the pedal hits the wall.
I'll measure how much throw the SC has and see if I can get away with a longer arm.
The '67:
The '59:
Not yet..
stussyrich
June 29, 2016, 21:19:19 pm »
I noticed with mine that if the arm wasn't perfectly centered when the pedal was depressed it would catch and seem to bottom out but it wasn't doing.
Quote from: Erlend / bug66 on June 29, 2016, 21:11:48 pm
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 21:25:42 pm »
Quote from: stussyrich on June 29, 2016, 21:19:19 pm
There is no movement up or down. It's on the millimeter throw wise.
The '67:
The '59:
Not yet..
bedjo78
June 29, 2016, 23:33:14 pm »
How to modify clutch arm? Weld it to make it longer ?
Or is it avalaible aftermarker parts?
Erlend / bug66
Global Moderator
SCC Event
June 29, 2016, 23:37:06 pm »
Quote from: bedjo78 on June 29, 2016, 23:33:14 pm
VW made 75mm and 100mm
The '67:
The '59:
Not yet..
June 30, 2016, 06:09:35 am »
I get the 100mm versions and cut them off at base of arm and do same to mendy arm then weld them on, will see if I got a pic of one
bedjo78
June 30, 2016, 14:11:57 pm »
[/quote]
[/quote]
Thanks I will make the same...
Stripped66
July 11, 2016, 01:42:54 am »
Quote from: Erlend / bug66 on June 29, 2016, 11:11:04 am
...line lock and restrictor valve for clutch management.
Assuming you have comparable leverage with your pedal setup, have you inspected/measured the size of the orifice in the line-lock? Several folks (myself included) found that the orifice in our line-locks were so restrictive that the Parker valve was the path of least resistance. The Biondo line-lock solenoid was the common denominator for at least 4 of us with this problem...FWIW.
Erlend / bug66
Global Moderator
SCC Event
Reply #29 on:
July 11, 2016, 08:05:24 am »
Quote from: Stripped66 on July 11, 2016, 01:42:54 am
I've heard the same issue. They can be bored out, but I need to bleed the clutch again, and I think I'll try to skip the management to see if the pedal is better without.
The '67:
The '59:
Not yet..
