September 21, 2026, 17:55:00 pm
| | |-+  Hydraulic clutch setup
Pages: 1 [2] Print
Author Topic: Hydraulic clutch setup  (Read 42463 times)
Stripped66
« Reply #30 on: July 11, 2016, 19:36:56 pm »
...line lock and restrictor valve for clutch management.
Assuming you have comparable leverage with your pedal setup, have you inspected/measured the size of the orifice in the line-lock? Several folks (myself included) found that the orifice in our line-locks were so restrictive that the Parker valve was the path of least resistance. The Biondo line-lock solenoid was the common denominator for at least 4 of us with this problem...FWIW.
I've heard the same issue. They can be bored out, but I need to bleed the clutch again, and I think I'll try to skip the management to see if the pedal is better without.
They *can* be bored out, but if you don't profile the orifice properly after doing so (or just get lucky), the solenoid may not release under pressure.
« Reply #31 on: July 25, 2016, 20:32:57 pm »
How to modify clutch arm? Weld it to make it longer ?
Or is it avalaible aftermarker parts?
I came across one I did a while ago while clearing some boxes today, this is for mendy
dragvw2180
« Reply #32 on: July 27, 2016, 13:26:45 pm »
 Simple hydraulics , small master / large slave = soft pedal  / less travel        this is mechanical advantage
                          large master / small slave = hard pedal  / more travel
   I have used a 3/4 master / 7/8 slave and plumbed it with AN4 ptfe lines for my street/race car with the double disc Rev 6 clutch . The pedal is still acceptable for driving on the street and it reacts like a cable during hard shifts . The plan is to raise my torsion housing 3" over the winter and I will do as Richie suggests with the 100 mm arm then .
bedjo78
« Reply #33 on: July 28, 2016, 15:28:38 pm »
Good idea if is it avalaible for sale ?
Pages: 1 [2] Print
